Need 4ohm load
Need 4ohm load
Old 31st May 2004, 03:20 PM   #1
clayton is offline clayton  United States
Question Need 4ohm load
I have 2 Fosgate HE12's 8ohms each. I want to add 2 more 12's. I want to keep amp bridged mono. I am running a punch 500.2 amp. If I got 1 that is 4ohm & 1 that is 8ohm would running them in series parralel. give me a 4ohm load. Any help would be great.
Old 31st May 2004, 04:20 PM   #2
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
You have no choice but to get 8 ohm woofers and wire the 4 in series-parallel for a total load of 8 ohms. Any other arrangement will not equally divide the power between all 4 woofers.
Old 31st May 2004, 04:39 PM   #3
Thanks for the input. I geuss I will just have to sell the 2 that I have & buy 4 4ohm woofers. I want to get the most out of this amp as possible. If you know of any other way to get more please let me know
Old 31st May 2004, 06:50 PM   #4
R.I.P.
8 ohm is very unusual for a car subwoofer.
If they are dual 4 ohm you can simply use one voice coil of
each driver without significantly affecting power handling.
sreten.
Old 31st May 2004, 07:41 PM   #5
They are single voice coil. I had orignally planned on using just the 2. But decided I wanted more. 8ohm is used in car audio alot.
Especially when using just 2 subs bridgeing a stereo amp mono.
Old 31st May 2004, 10:58 PM   #6
R.I.P.
Well are they sealed or vented ?
Vented will need the same volume for 2 drivers as 4 sealed drivers
but 2 drivers vented will manage more low bass than 4 sealed, and
~ double the amount of low bass juice the drivers can take.
sreten.
Old 31st May 2004, 11:25 PM   #7
They are sealed. I have not had any luck building vented enclosures. If you have diagrahm of a vented enclosure that would work with these subs that would be great.
Need 4ohm loadHide this!Advertise here!
Power load, dummy load (pic) luka Power Supplies 43 9th February 2012 02:50 PM
Dynamic load line analysis using music and speaker load Michael Koster Tubes / Valves 0 7th March 2008 08:47 PM
1 sub - DVC 4ohm each. What amp? big_kahunah Subwoofers 0 27th December 2006 12:22 AM
4ohm or 2 ohm sub on a JL 500/1? lukemc11 Car Audio 3 25th October 2004 12:25 AM
2 lm3886 for 120w in 4ohm load audioloud Chip Amps 10 29th June 2004 07:40 PM
Copyright ©1999-2017 diyAudio
