help troubleshooting XTANT 603x problem!
Old 28th May 2004, 02:03 PM   #1
pape is offline pape  United States
Default help troubleshooting XTANT 603x problem!
My Xtant 603x recently stopped working. One second it was playing find at low volume and with no pops or anything, no more sound. Checking the amp it was still on (power led). It turns on and shuts off properly, just no sound.
So I opened her up, nothing is burnt. Here is the strange part. On the board there is test points for voltage: +-18v (reads about 20), +-25v (reads about 30), +-42v (reads 42), and the kicker the +-52v reads .5 volts .
I tried testing all the tranistors (8 STP60NE06-16) and rectifiers (4 and I don't remember the part #'s) on the power supply. They seemed ok, I also desoldered the rectifiers and tested them off board, they check out. I guess I can take the transistors off and test them, but 8 is a lot of them and the solder used on the board doesn't like to stick to my desoldering braid.
Any other ideas on possible problems or what I should look for?
Note: Some idiot had mounted it to MDF at one point in time and being as the mounting screws are under the cover and the screws he used didn't like MDF, a screw fell out and shorted out one channel. So he replaced all the transistors on that channel and everything worked fine for 4 months until this problem.
Thanks,
Lee
Sorry for the length.
Old 1st June 2004, 04:26 PM   #2
hmmm was wondering if this would be better off posted in the Amplifier : Solid State forums? or is this the right place.
Old 2nd June 2004, 05:01 AM   #3
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
if you have an oscilloscope, check out all the waveforms on the primary and secondary of the transformer.
Old 2nd June 2004, 01:36 PM   #4
I do and will try that tonight.
It is a pain in the neck lugging it to my car all the time, hmm time to buy a 12v powersupply.
I was studying this: http://sound.westhost.com/project89.htm, to get a better understanding of an car amp power supply. It is a similar setup I think, except it seems to have 2 seperate supplies off of the one transformer. Each going to a bank of 4 STP60NE06-16. Learning little by little.
Thanks!
Old 3rd June 2004, 06:27 AM   #5
one more thing, you could do some retracing of the foil paths and see the components related to the output which dos not have any power going out and seeing which components are bad.
Old 4th June 2004, 12:34 PM   #6
Paradise_Ice is offline Paradise_Ice  United States
Paradise_Ice's Avatar
Could you not just ask Xtant? email them and detail your problem, am sure they could help, but maybe they would just blow you off, I think you have checked alot but may have missed something, God know i have done that in the past, take your sweet time and just check everything, i suspect that the transformer may be goosed, oh you dont need a 12 volt power supply, just use a battery.
Old 4th June 2004, 02:35 PM   #7
yeah I played around more yesterday. One of the FETs (P60NE0) and one of the Rectifires (FEP16CT) were making a chirping sound, all others were silent. Not sure what that means.
Also I think the point labeled +-52v on the board must be +- 0.52 since that is what the meter reads exactly.
Anyways I ordered new rectifiers and transistors and will replace them next week.
Thanks for the help.
Old 7th June 2004, 12:51 PM   #8
Hmm just thought of somethings. Since there is absolutely 0 voltage at the speaker outputs, I am wondering if it is something with the turn on delay. What would a delay circuit look like? It would kind of make sense.
Old 7th June 2004, 01:33 PM   #9
I figured out where it is, it is using a TIP30C for switching I think. More looking when I get home from work. I will figure it out someday.
Old 7th June 2004, 03:35 PM   #10
How did your amp stop working? I dont know much about Xtant but they work on certain voltage ranges right? no less than 11.5 and no more than 16 v, I am trying to buy a X1001 so i can make a copy. i live in Scotland and its only for my own personal use,so dont worry about me ripping anyboy off. How do you rate your Xtant? am having second thoughts now, yours seems troublsome.
help troubleshooting XTANT 603x problem!Hide this!Advertise here!
xtant 604 x mike49504 Car Audio 8 29th November 2008 09:00 AM
GainClone troubleshooting, major problem phorensic Chip Amps 6 13th June 2006 03:00 PM
Need component values for Xtant 603x Perry Babin Car Audio 3 14th March 2006 02:23 PM
Need somone with an older style Xtant 603x amp Stooo Car Audio 0 21st September 2004 12:53 AM
Troubleshooting Problem in Tube Preamp Audiofng Tubes / Valves 3 14th February 2003 12:12 AM
