Go Back   Home > Forums > General Interest > Car Audio
Old 26th May 2004, 05:46 PM   #1
Exclamation Broken SoundLab CPA 100 amp
Hi All,
i got hold off a broken SoundLab CPA 100 amp, screwed it open, only to see 1 resistance to be burned out.
(which was what i expected, the morron used water while working on it)
Now, the easy part would be to solder out the broken resistance (so i did), and then to replace it (which i cant).
Problem is, i can only see the 2 outer color rings, and NOT the middle 2 .. so i dont know what value i need.
What i do know: the resistance was green, its name on the board was L2, 1 outer circle is silver (so 10% more or less ..), the other outer side was brown (so 1).
Is anyone here in hold off this amp, and can tell me what the color rings are ?
Or does anyone know where to find the layout off the print including how to make it ? (and thus telling me L2 = ??Ohm)
Greetings,
Alwin van ombergen
Old 27th May 2004, 02:47 AM   #2
Immo_G is offline Immo_G  Australia
Wouldn't L2 infer it was an inductor, in those mini inductor 'resistor like' packaging. Not sure how the color code works for those.
Old 27th May 2004, 07:04 AM   #3
I supose it would, yes.
Funny part is that it really really really looks like a resistor, but not a normal one, but one made by rolling up tread.
Not sure what the english name on that one is though, english is not my native.
Would anyone happen to have one and is willing to take out the 4 screws for me ?
greetings!
Alwin
Old 27th May 2004, 07:24 AM   #4
Oke, did my research on this one,
Youre right, i CAN be an inductor.
with the 2 rings i can still see (silver and brown on the other side) and this webpage:
http://www.elexp.com/t_induct.htm
i can tell its a 10% tolerance inductor, i also know the first number is 1.
With the 2 rings missing it can be anything from 10 to 190.000µF
Not, it is as small as a resistance, so i guess its a small one (say under a thousant ?) but then again, it can still be a lot.
What if i would just try say 150, what would be the odds it works, and what the odds i break it ?
As said, it was a free amp, because this part was broken, so i am willing to just try something, but like to do it knowing what i am doing :-)
Thanx people!
Alwin
Soundlab CPA200 amplifier bruinbaard Solid State 3 30th March 2009 08:00 PM
Antique SoundLab AQ-1003 cfamily Car Audio 1 15th July 2006 02:27 AM
Soundlab voice coil setup AndrewT Multi-Way 1 17th August 2005 09:44 PM
Broken JBL 300.1 Amp. Help plz! Crustanthrope Car Audio 3 10th May 2005 10:02 PM
Page generated in 0.07239 seconds (74.04% PHP - 25.96% MySQL) with 10 queries
