2 amps. power problem
Old 25th May 2004, 12:59 PM   #1
Ryancowe is offline Ryancowe  United Kingdom
Default 2 amps. power problem
I have a 1200 watt amp and a 600 watt (i think). i am using the sony am for the subs (2x 1000watts JBL) and the smaller amp for the 2 6x9's. the problem is that wen there is just a huge burst of bass the 6x9's go really quiet until the bass is finished, then everything is fine. is this because the big sony amp is taking all the power from the batter so the smaller amp dont get enough???? av got 2 power leads running from the battery, also the remote cable and the earth have just been joined to the terminals on the sony amp. will it make any defference if both amps have there own earth and remote cable????
any suggestions
thanks
Old 25th May 2004, 04:44 PM   #2
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
u need to put a big capacitor on the rails of the "big" amp
usially 1 farrad
Old 26th May 2004, 06:18 PM   #3
would i be able to connect 1 amp to another battery??
Old 27th May 2004, 06:13 PM   #4
maylar is offline maylar  United States
If the 2nd amp is starving for voltage then your wiring is totally inadequate. I would get a voltmeter and check the power going to the amps and work back toward the battery until you find where the loss is. My guess is you have a bad connection somewhere.
dave
2 amps. power problemHide this!Advertise here!
SMPS for diy audio amps and multi-channel diy amps (and their power supplies) tlparker Solid State 20 12th May 2015 01:23 PM
Problem with PPI amps - POP on power on and power off Onkel Alex Car Audio 8 19th October 2008 08:48 PM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 03:21 PM
FS PA02 Power op-amps +/- 18v, 5 amps modifry Swap Meet 0 11th August 2004 08:45 PM
pre+power amps vs integrated amps pkgum Solid State 4 22nd November 2001 02:46 PM
Copyright ©1999-2017 diyAudio
