what bass box? - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 8th July 2004, 01:52 AM   #11
Send a message via MSN to charlyiy
Question HEY S.C
WHAT SIZE OF WOOFER DO YOU HAVE THERE? ON Y0UR TUBE BOX? CAN YOU SEND ME THE SIZE OF THE TUBE AND WHAT DID YOU USE ON MAKING IT? I WILL APRECCIATE YOUR HELP ....
AND IF SOMEONE CAN SEND ME A BOX SIZES FOR A 10" WOOFER FROM BOSCHMANN THE MODEL IS ZX-102XPRO.
TXZ AGAIN.
Old 8th July 2004, 01:43 PM   #12
Circlotron's Avatar
Originally posted by SkinnyBoy
and why did you make it round anyway?
Flat panels flex, round ones don't because the air pressure can only stretch them which is very difficult. I'd like to make one using a large diameter steel pipe.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 8th July 2004, 09:37 PM   #13
S.C is offline S.C  United States
Send a message via ICQ to S.C Send a message via AIM to S.C
It is just a "I want to try new things idea." The result is not bad at all, but I can't offer any comparison. I am using 12" there, but 10" will be better. I should have sent you a mail already so check your mail box.
Old 10th July 2004, 01:29 AM   #14
Talking working on the sonotube
txz s.c im looking where to find the sonotube and yep ! ! ! ! I have a 10" ! ! ! ! txz bud im glad to find ppl like you here
Old 10th July 2004, 02:57 AM   #15
Default a new question to s.c
been looking for that sonotube without any lucccckkkkkkkkk
gggrrrr....
could i use 10" pvc tube instead of the sonotube? will it make a huge difference?
Old 10th July 2004, 06:17 AM   #16
If I remember it correctly, some ppl said PVC tube will tend to vibrate. However, some ppl also use Pipe to make TL speakers. I think if you are using PVC--> plastic. Why don't you try Fiber glass? But u need to make sure the volume is right. We need input now ppl. This is all I can help him.
Old 27th July 2004, 07:12 PM   #17
hey S.C i found the sonotube ! ! ! ! it came in diferents sizes, wich one should i buy? it comes in 30 40 cms will be the better?
Old 28th July 2004, 04:31 AM   #18
If you have 10", the 10"-12" one will probably ok. 10" will look sharper because it is smaller in diameter and lengthier to fill ur trunk from side to side. My 12" used only the length of the left back seat. 10" will probably extend to the length of both seats. however, after some serious though I will suggest to go fiber glass. 1st, it save more space than sonotube, and second it will have more SPL even if u want to run them in SQ because isobaric set up will make two to equal one, unless u are running dual but not isobaric setting. Try it if u go non isobaric. After I heard my cuz's friend's sub, I really give up this sono. Mine is muddy, and lack of soundstage, and his is accurate, and the bass is enjoyable. So it is time to try new stuff.
Old 28th July 2004, 06:17 AM   #19
Grz is offline Grz  Germany
new? have a lok: http://www.hornlautsprecher.net/MonacorimGolf-2004.html
Peter
Dipole bass or Ripole Bass? MJL21193 Subwoofers 13 15th September 2008 08:42 AM
any electric bass players? im building a bass guitar cab KOA Instruments and Amps 27 30th April 2007 04:49 PM
DBA (dual bass arrays) and active bass traps capslock Subwoofers 3 20th August 2006 01:52 PM
32 ohm bass amp. Tweeker Instruments and Amps 5 9th March 2006 01:43 AM
For all Bass Junkies out there (Behringer Bass processor usage report) VEC7OR Digital Line Level 5 27th October 2003 10:18 AM
Copyright 1999-2017 diyAudio
