2 AMP's?????
2 AMP's?????
Old 22nd May 2004, 02:56 AM   #1
Ryancowe is offline Ryancowe  United Kingdom
Default 2 AMP's?????
i have 2 amps, 2x 10" 1000 watts JBL subs and 2x 500 watts 6x9's. will i be able to run the 2 amps of the same power cable running from the battery for the existing amp??? i tried it today, sounded awsome for 15 mins, then the fuse blew. will i be able to just put a new fuse in but increase the AMP's (30 amp in already, that blew, would 40 or 50 amp fuse be ok???).
thanks
Old 22nd May 2004, 04:19 AM   #2
Jean is offline Jean  United States
Jean's Avatar
Send a message via AIM to Jean
yes you should be able to run multiple amplifiers from the same power cable (what ga are your power wires?). what you should do is get two distribution blocks, one should be fused. don't change fuses in your amplifiers with higher rated ones, that way it won't protect your amplifier if something goes wrong with it. you might have to increase the fuse that you have in-line with the battery, should be under the hood really close to the battery, to accomodate two amplifiers.
left lane is for passing, slower traffic keep right please.
Old 22nd May 2004, 11:29 AM   #3
yeah thats wat a ment, not the Amplifier fuse, the fuse in the power cable, just inside the car at the front.....that was the one that blew yesterday. so if i increase that one it will be fine. any fuse size recomendations???
thanks
Old 22nd May 2004, 02:19 PM   #4
li_gangyi is offline li_gangyi  Singapore
li_gangyi's Avatar
what's your current rating?? Maybe 60A would be a good bet....
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 26th May 2004, 01:56 PM   #5
muskgrave is offline muskgrave  United States
Send a message via ICQ to muskgrave Send a message via AIM to muskgrave
if you want it to sound better I would sell those 6x9's and get some JL Audio 6.5's or infinity kappa 6.5's. Also it would help to know RMS power rather than "max" power. Also make sure your ground is as big or bigger than the power wire and as short as possible.
dlv
Old 26th May 2004, 04:39 PM   #6
Stocker is offline Stocker  United States
Check the IASCA chart for power vs. wire guage before upgrading the main fuse! You don't want to burn your car down.
Jesus loves you.
2 AMP's?????Hide this!Advertise here!
Resources saved on this page: MySQL 17.65%
