I have recently bought some speakers for my car. I have a 2 channel 800watt kenwood amplifier.
2 12" 700watt max, 175 watt rms subwoofers 2 6X9 three way 300 watt rated power mids 2 5 1/4" 200 watt max 100 watt rms mids 4 tweeters Will the amplifer i have be able to power these speakers with sufficient energy? |
#2 |
How can you connect them???/
#3 |
Well, I personally think this amp will not be usefull for all speakers. If the amp is bridgeable to 2 ohms, connect only the 2 subs in paralel to the bridge output and see if the amp is stable.
If soooooo, You need to buy another amp in order to power up the remaining spks. It is not possible to power up all speakes, specially for a 2 channel amp. If radio has good output, conect all speakers to radio and use the amp for the subwoofers. |
#4 |
Watts mean nothing, hook them up as you would and make sure gain is set properly.
Oh and I also don't think you can power all of your speakers from the same amp with credible results. Split up the audio spectrum with a x-o after the deck and power with sepereate amplifiers.
ERTW 4 life! "the day has 24hours. If that is not enough take the night."-Roemhild |
| Would this work ? | LesPaulStandard | Instruments and Amps | 3 | 4th May 2006 02:14 AM |
| Will This Work? | sousmielie | Class D | 6 | 27th December 2005 05:53 PM |
| It Should Not Work ! | f4bok | Solid State | 3 | 6th September 2004 05:33 PM |
| Would this work? | JoeBob | Solid State | 5 | 18th July 2003 03:40 PM |
