diyAudio (
-   Car Audio (
-   -   noise in right speaker when engine on (
crazyinjun 30th April 2004 06:19 AM
Hey, maybe someone can help me out. I have a 97 Nissan Pathfinder and i have been getting this fuzzy noise coming out from only my right speaker. i have teseted it, and it seems to be that entire conneciton. the problem is is that the noise does not come when i have it in "accessory" mode....only when the engine is running. I though it might be a loose ground wire, but i tried testing that and i couldn't fix it. I was also thinking of wiring a capacitor somewhere on that ground and voltage....any ideas?
audioPT 30th April 2004 01:28 PM
Let me try to help.
First answer this:
- Head Unit right into the speaker or using an amplifier;
- Speaker wired in single-end or bridge;
- If using an amplifier, where did you connect the ground;
- If using an amplifier, where the audio cables are passing.
After that, I'll post something to help you.
Pedro Martins
crazyinjun 30th April 2004 04:13 PM
its the head unit going right to the amp or anything hooked up. thanks for posting.....its all factory so i think its single-end
audioPT 30th April 2004 06:49 PM
There is any filter in the DC power input of the head unit?
If not, install one.
But there may be any trouble inside the head unit...
The noise you hear comes from the 'alternator' (I think its the word in english ;))
crazyinjun 1st May 2004 03:05 AM
by you mean capacitor? and should it just be going to the 12 VDC line in and the ground? thanks for your help...........yea..its' called an alternator over here.
audioPT 4th May 2004 08:42 AM
2 Attachment(s)
Something like this:
djQUAN 4th May 2004 09:49 AM
I also have a nissan pathfinder (known as terrano over here)
and I have installed a 440 watt system in it without any probs.
it is weird that you have noise only in one speaker. the filter might not help since if it is from the power wire, then there should be noise in both speakers. a possibility could be that the speaker wire was clamped and is contacting/shorting to ground.
is it an aftermarket stereo or the factory system?
crazyinjun 4th May 2004 05:11 PM is the factory clarion speakers....i actually tried hooking that diagram up but it blew out my fuse. i also tried putting a capacitor for just the speaker line, but that didn't work.. i ended up taking out the speaker of my panel, and hooking up a new wire to it...that seemed to work, so i guess the problem is in the wiring somewhere..its probably running by some big electrtical component which is causing the noise. thanks for your help!
audioPT 4th May 2004 07:28 PM
Maybe some new phisics law ;) ;)
Of course... This will create a low pass filter not good enough to kill the noise... BUT GOOD ENOUGH TO KILL THE POWER AMPLIFIER!
Maybe some wire is close/parallel to the power line (+)
crazyinjun 4th May 2004 08:22 PM
yea..i thought that a wire might be close to the 12 vdc line, but wouldn't that noise have been coming for the whole life of the car? do i need to add that inductor to make that filter work?
Resources saved on this page: MySQL 18.75%
