#11 |
"speaker wire was clamped and is contacting/shorting to ground."
there is still normal sound coming through the front right speaker, but there is also an additonal fuzzy noise......so i don't think that the wire is grounded otherwise there wouldn't be any sound coming through... also, the speaker only produces this noise when the engine is on. in accessory mode, the speaker acts normal. must be the 12vdc engine line |
#12 |
how did it come out? did it just appear for no reason or you installed something then it appeared?
#13 |
Answer: Only when engine is running, but not in ACC mode:
Because, the cables that come from the distribuitor to the sparks (high something cables) internaly have a resistance measured in Ohms. Check and see if these cables are well connected (clean terminals). Make sure you didn't buy cheap cables. Check order of connection before disconnecting. If problem is not solved, check for speaker cables that come from the radio not to be broken and making contact with ground. Get a long enough cable, connect to radio and to speaker( make sure to diconnect old one (just to try) Also check that speaker terminals are not grounded when screwed. This will solve it |
#14 |
It was raining one day, and the next day it happened. I have no clue what it was...maybe some moisture leaked in the speaker wire somewhere.
Thanks for the help |
| engine noise - bad amp?? | Dan2 | Car Audio | 43 | 5th November 2008 09:26 AM |
| engine noise problem, HELP!!!! | TheStape | Car Audio | 2 | 14th November 2007 04:29 AM |
| Engine noise | makaveli956 | Car Audio | 26 | 3rd June 2007 06:40 AM |
| Engine noise (tried almost everything) please help! | wally91chevrole | Car Audio | 34 | 26th February 2006 05:41 AM |
| engine noise HELP! | st33lownz | Car Audio | 6 | 4th November 2004 06:35 PM |
| Page generated in 0.06703 seconds (80.85% PHP - 19.15% MySQL) with 11 queries |
