How's this sound for 8" components - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 30th April 2004, 04:40 AM   #1
fivaxis is offline fivaxis  United States
Default How's this sound for 8" components
Well there's hardly any 8" components available so this is what I am thinking of
http://www.partsexpress.com/pe/pshow...=297-310&DID=7
http://www.partsexpress.com/pe/pshow...=264-590&DID=7
http://www.partsexpress.com/pe/showd...number=260-144
Does this sound like it would go together well?
Old 30th April 2004, 08:02 AM   #2
diyAudio Member RIP
The crossover should work in car if it allows for typical inductance,
also an L-pad may be needed for tweeter level adjustment.
However mounting the 8" bass unit correctly is not trivial.
TBH I can't the rational for going for an 8" bass + tweeter over
a high quality pair of 6.5"/7" + tweeter and all the mounting bits.
And you get a 4 ohm system rather than 8ohm that will extract
twice the juice from your presumably 4 ohm capable amplifier.
I've nearly always found extra padding on the tweeter useful for
in-car component kits, tweeters are nearly always set too high.
This is good value :
http://www.discountave.net/kfke7miand1t.html
But with 6.5"/1" you can almost name your price, for your budget :
http://www.discountave.net/16foac65.html
looks good.
sreten.
Old 30th April 2004, 02:00 PM   #3
Really my only concern is tweeter to woofer level. Mounting will be no problem, I have plenty of room in my doors - they have 6x8 holes, just needs a little trimming to fit 8s.
It's really hard to get any decent bass out of 6.5s in a door.
Old 30th April 2004, 02:53 PM   #4
Lusso5 is offline Lusso5  United States
Lusso5's Avatar
Default Good info
I'll let you in on some good info.
Dynaudio was contracted to build a custom system for the Volvo C70. The drivers are pretty close to the standard Dynaudio Mobile drivers. I used to own a C70, so I know the system well. It consisted of a System 360 3-way up front:
MW170 8" woofers, MD140 3" Dome mids, MD100 tweets.
And a system 260 2-way in the rear.
MW170 8" woofers, MD100 tweets.
The woofers had redesigned baskets to make the a little more shallow, to fit, and the tweets have funky mounting brakets, but the rest of the driver is all classic Dynaudio - 3" Hex VC in all.
Here is the best part - you can get these drivers for a fraction of what they cost in the audio stores - about half.
www.volvopartsworld.com is a great source for wholesale prices. Make sure to tell them you want the internet parts price.
The 8" Dynaudio is a great driver, and has great HF extension, and smooth roll off. If I were doing an 8" two-way, I would use this driver.
I disagree, that you cant get good bass out of a 6.5-7".
I just built a component set for my car with the Morel MW-168 (4ohm), which is a 6", and the Vifa D26NC05 (6ohm), and it is very good bass extension. (FR plot below) E-mail me if you want the x-over schematic.
Trust Sreten's comments about the padding too. I needed 6db of attenuation on my tweeter in the above referenced system.
Old 30th April 2004, 08:45 PM   #5
diyAudio Member RIP
Well the laws of physics indicate otherwise, and if the total door
volume available for the driver is limited, smaller units will have
more extended bass, but lower sensitivity and maximum levels.
sreten.
Old 30th April 2004, 09:01 PM   #6
The only time I've had 6.5s put out decent bass, they were in a tiny tiny enclosure sealed into the floor. A door is a huge enclosure that would in no way limit the lower frequency excursion of an 8" speaker.
Speaker components "Inbound into customs" for almost 4 weeks runethechamp Everything Else 5 14th April 2009 04:27 PM
1970's Pioneer sound system. Finding matching components?. Michae1 Analog Line Level 7 9th May 2008 04:42 PM
The "How much will you pay for these (surprisingly useful) components?" thread. Spasticteapot Swap Meet 3 12th April 2006 03:44 PM
Amperes, volts, ohms, "blowing" electronic components... Datoyminaytah Car Audio 6 17th August 2004 03:19 AM
Components and Sound Quality fmak Solid State 2 22nd February 2003 04:22 PM
Copyright 1999-2017 diyAudio
