diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   Any point in putting dummy loads on unused speaker outputs on headunit? (http://www.diyaudio.com/forums/car-audio/33122-putting-dummy-loads-unused-speaker-outputs-headunit.html)
eRiCdWoNg 28th April 2004 03:42 PM
Just throwing this one out here... any point in using say a 8 ohm dummy resister for the headunit to 'drive" with its spekaer outputs instead of it driving a inf. ohm load when nothing is connected? In my setups I always use just the preamp outputs to drive external amps. Thanks.
RobM 28th April 2004 03:56 PM
Just creating extra heat in the head unit and the resistor. I definitely wouldn't do it.
I've used an internal amplifier successfully as a balanced output, so they're not entirely useless.
djQUAN 6th May 2004 08:12 AM
balanced output? good idea but I think that the high level outputs don't have very good SQ compared to the preamp outputs........
Resources saved on this page: MySQL 18.75%
