http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=48613&item=3092522482
that is the sub and box kit i have a sony xplod amp 120rms x 1 will this amp push this at all?
Banned
Joined 2002
well back to his orginal question..
the sub is rated at 400rms , and you say you have a 120x1rms?
well it will work.. the sub will be severely underpowered.
i am pretty sure there will not be much sound quality hence the box is prefab and un-tuned.
don't forget you will probably need a 12v source for the box
everything total is 105 shipped.
IMO
If you want to DiY, you can definitly pick up a decent sub for about 60-$70, and if you have the tools, buy some MDF and build your own box, also this way you can tune it accordingly to a SQ or SPL application.. more than likely this way you will save trunk space!
IMO
well i can assume that this would be your first system?
just go for it.. whether your amp puts out 120rms or 400rms, the sub will still move, but preferably 400rms This is an "acceptable" deal if it is your first system.
besides im pretty sure down the road, if you do still like car audio, you will obviously upgrade....
I would also suggest you check out the Diamond CM3, Kicker CompVR, PG Ti. All great entry level subwoofers.
