Hifonics BXI-6000D
I have installed the last two drivers i had. Both are not working. This time i used speacial solder equipment and was very careful not to overheat. Anyhow, i expect, i received counterfeit parts from ut source. I will order new parts from german seller.
Thanks a lot for assistance.
Achim
So, continue. Got the parts, but another problem. Amp is not powering up. Found, that on the Driver Board for Power supply on VCC is only 2,3V. If i connect 12V on that pin amp is powering up and power supply is working. During that condition i checked audio driver board and now on both irs8442 i got only dc. But thats later. Where i have to look, to got 12vdc on that VCC Pin?
