Hifonics BXI-6000D
Hifonics BXI-6000D
Old 9th August 2018, 05:02 PM   #131
Achim1409 is offline Achim1409  Germany
if i connect a 9V Battery the sawtooth signal is disorted.
Old 9th August 2018, 05:04 PM   #132
Perry Babin is offline Perry Babin  United States
Is the voltage on the 9v battery being pulled down?
Old 9th August 2018, 05:10 PM   #133
No, not pulled down. If i start the amp with the battery allready connected, i have no more drive signal on both sides. Also it seems no voltage. The oscy is staying in center.
Old 9th August 2018, 05:15 PM   #134
If you have the tutorial, I'd suggest going to a low-voltage power source (last item in the 'type 3 page of the tutoria)l. It involves removing the rectifiers and adding windings to one transformer. It's much safer and you can test with all components in the circuit with little chance of damaging them.
Old 9th August 2018, 05:16 PM   #135
yes, i have since 2 days. but a lot to read. i will try later.
Old 10th August 2018, 02:02 PM   #136
So, i have tried with fets inside, but than there is at this side no signal at all. If i connect the 9V batterie, there is no change, also the battery is not dropping.
I dont understand, how the 10v are generated. I have compared the values of the working side with the not working one, but there are no big differences.
According IRS Datasheet, VB(13) is connected with a capacitor to VS(11). VS is on the center pin of mosfet low side. 13 should over a diode connected to vcc.
Old 10th August 2018, 02:17 PM   #137
Just to confirm, do you still have a good signal on pin 6 and the FETs that are driven by pin 6?
The Vs pin is connected to the low side drain and the high-side source. The high-side drive circuit floats. Did you reconnect the wire that you removed?
Old 10th August 2018, 02:22 PM   #138
The cable is reconnected. on Pin 6 i have no more signal. On Pin1 the signal is much weaker as on pin 1 working side.
Old 10th August 2018, 02:35 PM   #139
Is the signal strong on the driven side of the 10k resistor that connects the drive circuit to pin 1?
Old 10th August 2018, 02:39 PM   #140
Yes it is. Much stronger. MEasured the value of that resistor. 9,5k
Hifonics BXI-6000DHide this!Advertise here!
Power Acoustik GT1-6000D RJohns777 Car Audio 19 2nd July 2018 06:27 PM
SPL APE1-6000D clintronics Class D 4 16th May 2018 06:53 PM
Lanzar optidrive 6000d megael9 Car Audio 8 14th August 2015 04:40 PM
Hifonics ODIN VI and Hifonics CYCLOPS VI seankane Car Audio 5 1st December 2013 07:23 PM
PPI D1-6000D mbates14 Car Audio 6 16th May 2013 01:22 AM
