D2 Powerhouse Earthquake amplifier. Power supply down.
Old 9th July 2018, 01:05 AM   #61
Perry Babin is offline Perry Babin  United States
Remove the outputs and check them with the meter set to ohms.
Leave the outputs out and desolder all pads. Reinstall the rectifiers. Get the voltages on the 4080 if there are no problems (components overheating, excessive current draw...).
Old 9th July 2018, 01:20 AM   #62
rhempz01 is online now rhempz01  United States
Ok. Thanks perry.
Old 9th July 2018, 07:49 PM   #63
So the new 4080 is bad now and with a new one and the rectifiers installed there is something pulling down the power supply. The power supply starts up draws .89amps then up to 1.12amps after the rectifiers and 4080 is installed .28 amps. And the sound from the front torrid I'd back.
Old 9th July 2018, 07:52 PM   #64
What do you mean by 'pulling down the supply'?
Old 10th July 2018, 11:56 PM   #65
Sorry the current goes from .80 to 12.5v to .22amps 12.3v. no outputs just rectifiers (checked the rectifiers again) and the 4080 in curcuit.
Old 10th July 2018, 11:59 PM   #66
I don't see a problem, other than the regulator in your power supply may be a bit off. If it was pulling the supply down to 5 or 10v and the current increased, then, there may be a problem.
Old 12th July 2018, 07:17 PM   #67
Ok perry so just use different outputs this time around. My concern is why the new 4080 failed after I installed it. The output transistors? But all of them tested good. Open between gate and source?
Old 12th July 2018, 10:19 PM   #68
Did they test open gate to drain?
Read section 26 on the class D troubleshooting page (CDTS). It shows how to check the drive signals without the outputs in the circuit.
Old 13th July 2018, 04:38 PM   #69
New outputs everything is installed and the amp still doesn't reach over .22amps of current.
D2 Powerhouse Earthquake amplifier. Power supply down.Hide this!Advertise here!
Earthquake Powerhouse D2 hifonics hugh Car Audio 101 17th June 2016 09:19 PM
Earthquake PowerHouse D2 outputs DC and high pitched squealing noise Purpose Car Audio 8 28th April 2015 01:53 AM
alteration of the power supply from the power amplifier Harman Kardon HK870 at 220. alexkmp3 Power Supplies 4 11th December 2012 04:39 PM
earthquake 200dhc power supply repair ivkata Car Audio 1 18th April 2012 08:54 AM
Is this amplifier any good? (earthquake) thomas997 Solid State 2 4th March 2004 01:44 AM
