Kicker CXA1800.1 Flashing in and out of protection
Old 27th June 2018, 03:27 PM   #51
rhempz01 is offline rhempz01  United States
That did it bill the 393 was bad. I replaced it and the pin 7 signal came back for a moment and now it is gone again.
Old 27th June 2018, 03:57 PM   #52
From main ground to pin 1 157.9ohms
Pin 2 160.8ohms. did you want the resistance between pin 1 and pin 7?
Old 28th June 2018, 01:04 AM   #53
PapaZBill is offline PapaZBill  United States
PapaZBill's Avatar
When you say Pin to are you referring to Pin 7?
You may want to replace IC14-IRS20957 and maybe D103- BAT54C.
I'm a bit stomped. The power supply works, The PWM works, You have Drive out of IC11 Pin 1 but not Pin 7.
There may be something in the in the output on the IC14 side, that's dragging down the drive. If replacing IC14 you still don't have drive, take a close look at the outputs for shorted output devices or broken leads, traces,bad solder joints, open gate resistors, bad gate drivers.
Any sufficiently advanced technology is indistinguishable from magic.
Arthur C. Clarke
Old 10th July 2018, 11:58 PM   #54
what would make one of these fail to start up i have a simular curcuit design in an amplifier that will only draw .3amps of current and wont power up. i can not seem to find the cause?
Kicker CXA1800.1 Flashing in and out of protectionHide this!Advertise here!
Kicker CXA1800.1 low audio problem. rhempz01 Car Audio 26 21st May 2018 10:21 PM
Kicker 1500.1 (2009) Protection Flashing Slowly rhempz01 Car Audio 37 1st April 2017 02:52 AM
Kicker zx1000.1 power badge flashing feka87 Car Audio 7 12th July 2016 01:19 AM
Kicker KX600.4 protects and led alternately flashing nonprof Car Audio 14 1st June 2016 04:20 AM
Kicker 1302 Protection Scanlines Car Audio 3 27th January 2010 08:01 PM
