Kicker CXA1800.1 Flashing in and out of protection
Old 13th June 2018, 01:25 PM   #31
rhempz01 is offline rhempz01  United States
So after a full night of reading about diodes, zeners. I probably need a specific model. In the voltage ladder, do you have a part number for those diodes?
Old 14th June 2018, 06:35 PM   #32
PapaZBill is offline PapaZBill  United States
PapaZBill's Avatar
I can't really say for sure what make of diode is in the CXA18001 but here are three I found on Mouser. 11v 12v and 24v .5 watt 5% 0805 smd
You won't need the 11v as I'm sure ZD7 is good. These are 1/2 watt. I mentioned 1 watt in a previous post, but 1/2w is plenty.
Mouser or Digikey is your best bet. If you can't find the Vishay in stock, just be sure to get 1/2 watt or better, 5%, 0805's. If you find something that isn't barrel shaped as long as its an 0805 SMD and has the same zener voltage and .5 watt rating at 5% they will do.
TZQ5242B-GS18 Vishay Semiconductors | Mouser
TZQ5252B-GS08 Vishay Semiconductors | Mouser
TZQ5241B-GS18 Vishay Semiconductors | Mouser
Any sufficiently advanced technology is indistinguishable from magic.
Arthur C. Clarke
Old 14th June 2018, 09:52 PM   #33
Ok great those are exactly what I ordered I ordered. Thanks
Old 19th June 2018, 07:51 PM   #34
This is after replacing all the zenners with the proper 12-24-12-11
ZD3- +/-_2.267volts
ZD4- +/-.786__volts
ZD5- +/-_12.67_volts
Old 19th June 2018, 08:19 PM   #35
Can u tell me what rating diode goes in zd10 (15v?), and capacitor in c60? I verified all the caps in c61,62,63 100nf spot on and replaced all the diodes as instructed, still no audio. Voltages are still the same as above.
Old 19th June 2018, 08:57 PM   #36
I believe the resistor r175 is out of tolerance.
Old 19th June 2018, 09:41 PM   #37
This is on the ground speaker terminal. I pulled the 27ohm resistor and it's open.
Old 20th June 2018, 01:21 AM   #38
PapaZBill's Avatar
The voltages across ZD4 & ZD3 indicates that C61-100nf is bad.
Even though it reads in value you should replace it. I have seen this exact failure multiple times.
It is possible IC10-TL072 may be shorted Pin 8 to Pin 4, and is dragging down the voltages across ZD4 & ZD3. If necessary replace it but I would definitely replace C61.
Leave R175 out of circuit. You won't need to replace until you have the Ladder Circuit fixed. And when you do, also check R173, 174, 273, 274- 16 ohm.
Are you sure the zener diode is ZD10?
Arthur C. Clarke
Old 20th June 2018, 01:36 AM   #39
PapaZBill's Avatar
I found ZD10.
I'm fairly certain it is an 18v zener. If you measure the voltage across ZD11 you should see appoximately 18 volts. If you post your reading I'll can better answer your question
Arthur C. Clarke
Old 20th June 2018, 05:02 PM   #40
So I replaced the ic9 because I did have short between pins 4-9. Still the pins are shorted? Also, zd11 is 16.5vdc so Ishould i use 17v in zd10. C60 I will replace it as well just need the value? And I ordered to incorrect parts for the capacitors so I sent off a new order yesterday, mouser parts usually arrive in 3 days.
Kicker CXA1800.1 Flashing in and out of protectionHide this!Advertise here!
Kicker CXA1800.1 low audio problem. rhempz01 Car Audio 26 21st May 2018 10:21 PM
Kicker 1500.1 (2009) Protection Flashing Slowly rhempz01 Car Audio 37 1st April 2017 02:52 AM
Kicker zx1000.1 power badge flashing feka87 Car Audio 7 12th July 2016 01:19 AM
Kicker KX600.4 protects and led alternately flashing nonprof Car Audio 14 1st June 2016 04:20 AM
Kicker 1302 Protection Scanlines Car Audio 3 27th January 2010 08:01 PM
