Rockford Fosgate 250m2, badly beaten up
Old 18th July 2018, 02:39 PM   #51
manninen is offline manninen  Finland
manninen's Avatar
There is traces on both side of board on TO92s but on board does not have sleeves to connect both sides.
i had to solder those properly on both sides. Thats why there was so random stuff going on.
channel works again and eight vbe matched transistors gives 16mV of dc out
Old 18th July 2018, 02:42 PM   #52
Perry Babin is offline Perry Babin  United States
The sleeves are called vias or feed-throughs. They were damaged at some point when someone removed the transistors.
Old 18th July 2018, 03:56 PM   #53
manninen's Avatar
Could be so, this thing has many components changed all over the board. Just one different TO92 but all these holes does not feed through, other channels TO92's look untouched.
Old 18th July 2018, 10:18 PM   #54
manninen's Avatar
Originally Posted by Perry Babin View Post
Qx24 and Qx25.
As my journey is this far im not gonna leave it to 16mV. (sure heat it up properly to see hot numbers later)
What is your opinion now when all transistors are sort of pairs, am i gonna just take just little bit stronger transistor to Qx25 Qx24? and if looking to that another channels, those hot TO92's does it matter for effiency or something else if there aint good pairs? i have all eight allready choosen, just thinking if i take short or long course. Change them all and then Q324 Q325.
In factory i bet they havent choosen any components, just hit them in from same batch
Old 19th July 2018, 12:09 PM   #55
manninen's Avatar
Took short course and changed Q325 and Q325 only.
dcs around 6,4mV cold and after warming up ~9mV and ~13mV
slight blow to TO92 cluster and goes under 0mV.
I put outdoor temperature sensor between those and temp passed meters 70C max, so they run 70-80deg
Rockford Fosgate 250m2, badly beaten upHide this!Advertise here!
Rockford Fosgate 600.5 mike49504 Car Audio 70 22nd June 2012 10:38 PM
Rockford Fosgate Punch 250m2 seankane Car Audio 2 1st February 2012 04:21 AM
Rockford Fosgate 800 a2 mike49504 Car Audio 1 8th July 2011 06:33 PM
Rockford Fosgate 250m2 seankane Car Audio 2 14th June 2011 11:00 PM
Rockford Fosgate P75.2 chipper Car Audio 9 3rd January 2011 03:20 AM
