Hifonics brx2416.1d
Hifonics brx2416.1d
Old 20th April 2018, 07:44 PM   #1
rhempz01 is offline rhempz01  United States
Default Hifonics brx2416.1d
I started looking at an amp for a friend, it draws current but no fets are shorted? It had a blown in half diode d12 and four of the caps look swollen, d23 reads shorted in circuit.
Old 21st April 2018, 01:59 AM   #2
Perry Babin is offline Perry Babin  United States
Some of the windings on the inductor seem darker than the rest. It could just be the lighting.
D12?
D23?
Old 21st April 2018, 04:08 PM   #3
Pulled and checked d23, it's good. And replaced d12 with same result. Pull supply load down to 8vdc 4amps of current. I'll check the inductor.
Old 22nd April 2018, 07:20 PM   #4
Just the lighting in the photo. I think i am going to remove the fets and check them and the drive. Start there.
Old 22nd April 2018, 09:11 PM   #5
What supply are you using that gets pulled down to 8v with 4 amps of current?
Old 23rd April 2018, 06:15 PM   #6
15v 10amp. I'm tracing the outputstage now perry. Without the rectifiers in the amplifier, it no longer draws current. I should not have 10.8v on the gate leg of, one side of fets. I am looking at the driver board voltages now, shouldn't I have a +-15v going to the board?
Old 23rd April 2018, 06:45 PM   #7
That 11v is coming directly from the ic ( not sure of it's orientation heat sink is still attached.) Leg 6 I believe I can see under it.
Old 23rd April 2018, 07:32 PM   #8
I'm not familiar with this specific board but if it's like the larger boards, you will have +15, +5 and -5 and a 12v that is referenced to the negative rail.
Old 23rd April 2018, 07:47 PM   #9
Yet I have that 11vdc coming out of pin 6 of the driver I/c going to the gates.
Old 23rd April 2018, 07:54 PM   #10
Solder a bridge between pins 2 and 3 of the driver IC. Do you still have output from the IC?
Hifonics brx2416.1dHide this!Advertise here!
hifonics 5ch ian33 Car Audio 3 30th June 2015 05:43 PM
Does the hifonics thor VII & VIII use the same rail switching as hifonics zeus VIII coomaster1 Car Audio 5 8th May 2015 04:59 PM
Hifonics Zeus VII amp or Hifonics Zeus VIII amp coomaster1 Car Audio 15 11th May 2014 09:58 PM
Hifonics ODIN VI and Hifonics CYCLOPS VI seankane Car Audio 5 1st December 2013 07:23 PM
Hifonics amp mike49504 Car Audio 10 5th January 2011 05:01 PM
