Ok, so I have this amplifier. This amplifier had a damaged output section and power supply has violently blown. I cleaned all that up removed the ps driver board replaced the drivers and the 494. This isn't the first amp that has done this to me. This exact thing. So I used 47ohm gate resistors and 3205's in the power section. Cleaned everything up had a excellent drive signal. So I fitted the 3205's and the amp just flashes in and out of protection.
I don't know if photos will be enough for me to help but the quality of those was not good enough. If you are going to need help, you need to invest in a camera. You don't need an expensive one. You can likely get one good enough on ebay for $20. The following is from a lowly coolpix 2200 (2MP).
http://www.bcae1.com/repairbasicsforbcae1/images/phototutorial/DSCN5853.JPG
- General Interest
- Car Audio
- Audiopipe APMI-2000
