Rockford Punch 800a2
Old 16th April 2018, 01:53 PM   #1
imraneesa is offline imraneesa
Default Rockford Punch 800a2
hi,
Complaint is speaker wires shorted and the amp stopped playing.
Outputs are fine. getting -18.8v on adj pin of lm337 and 18.8v on lm317.
there is not much voltage on opamps. Can anybody provide me circuit for the same amp will be appreciated. i have to trace why there is no voltage on opamps.
Thank you,
Best Regards
Imran Mohammad
Old 16th April 2018, 04:23 PM   #2
Perry Babin is offline Perry Babin  United States
Board PC#?
Old 16th April 2018, 04:32 PM   #3
Originally Posted by Perry Babin View Post
Board PC#?
Pc-2038-F
Old 16th April 2018, 04:55 PM   #4
closest I have.
Old 16th April 2018, 06:45 PM   #5
closest I have.
Thank you very much sir. I removed all the opamps and the voltage came back on +ve pin showing 20v and -ve pin showing -20v. But as soon as i replace one opamp both +ve and -ve pins of opamps having only negative voltage. -15v on negative pin and -11v on positive pin.
Old 16th April 2018, 06:56 PM   #6
Is R41 within tolerance?
Old 16th April 2018, 08:52 PM   #7
R41 is with in tolerance. But I had replaced D3 before because it was bad. I replaced it with 1n4007 instead 1n4003.
Old 16th April 2018, 11:14 PM   #8
Do you read 0 ohms from the RCA shields to one end of R41 and 0 ohms from the other end of R41 to the primary ground terminal?
Old 17th April 2018, 02:58 AM   #9
R16 and R25 both gone too much high. I replaced those with 1/4watt through hole resistors and I got the output signals. Don't know why those two resistors gone bad.
Rockford Punch 800a2Hide this!Advertise here!
Rockford Fosgate punch 800a2 channel repair chipper Car Audio 16 23rd September 2015 10:50 PM
rockford fosgate punch 800a2 non working chipper Car Audio 8 27th May 2012 09:13 PM
Rockford Fosgate Punch 800a2 seankane Car Audio 3 25th June 2011 05:18 AM
Rockford Punch 800a2 seankane Car Audio 28 5th April 2011 01:27 AM
punch 800a2 $100?? chipper Car Audio 6 8th July 2010 06:21 AM
