Alpine PDX M6 - 43VDC Output
Old 5th April 2018, 01:45 PM   #11
Mbrogz3000 is offline Mbrogz3000  United States
The PDX and refurbed sub have been fine, but the 43VDC problem came back temporarily this morning - I think its influenced by minor cold temperature shock: 50 F weather yesterday, which rapidly swung to 25 F overnight and stayed there (I park outside), the truck and amp are cold soaked at 25 F. As soon as the amp turned on cold with no music signal, the sub pushed out. Shut off the radio, and I could hear the sub return to its rest. After 15 min of driving, and flipping the radio on and off, eventually the amp didn't saturate the output, and I was able to listen to the stereo at a reasonable 'morning' level.
The amp has an intermittent issue which will be very difficult to chase. I suppose I could stick the amp in the freezer (in a ziplock)) for overnight, then bench test it. Keep in mind that the board had no glaring or visual clues - it still looked new inside. Should I just swap out the output FETs as a starting point and see if the problem goes away?
Old 5th April 2018, 01:52 PM   #12
Perry Babin is offline Perry Babin  United States
You can use component cooler or canned air (inverted to dispense liquid) to spot cool areas.
Old 5th April 2018, 02:37 PM   #13
Thanks Perry - I will give some cold spot checking a shot once I get some time to pull it out again.
Alpine PDX M6 - 43VDC OutputHide this!Advertise here!
Alpine mpr-500 output help rhempz01 Car Audio 2 12th March 2018 11:51 AM
Alpine MRD-M501 no output krsteve Car Audio 7 26th September 2016 02:28 PM
FS : AudioPower DPS-500/DA SMPS @ ~+/-43Vdc pinnocchio Swap Meet 4 14th March 2015 05:21 PM
Alpine cda 7995 no output amc32 Car Audio 10 16th April 2009 09:45 PM
Alpine MRD-605 no output cobology Class D 0 21st February 2009 12:45 AM
