Hey guys,
This seemed like a pretty good place for technical knowledge on these things..
So long story short I have a old ZR360 that I got ages ago but has sat unused till just lately, I got it under the understanding that it needed work.
I powered it up, it got hot, yellow and red lights were on, so I shut it down and took it apart.
Found a shorted TIP35C transistor. Also found some dodgy work that someone else had done. I *think* there is supposed to be a inline fuse to protect the RCAs, that was missing and had a piece of wire soldered in its place. I assume that is supposed to be a fuse? Anyone have any idea what value it needs to be?
I also was reading that all transistors on the channel should be replaced when one goes bad.
If I understand this right the TIP35Cs are on the negative rail, do I need to replace just those or the TIP36s that are on the positive rail too.
I should post a few pictures, I can't tell if some other mosfets have been changed. but someone has worked in that area.
thanks for any help!
I was hoping the Kicker tech would visit. Until he does...
I would replace all of the outputs in the blown channel. Check the emitter resistors as well.
TIP35s are on the positive rail, if I'm not mistaken.
If the solder pad/screw hold near the transformer is electrically connected to the transformer secondary, I'd use a nylon screw to screw the board down there.
Can you post a photo where you believe a fuse should be?
Ok, here's what I got.
for whatever ends I cannot upload to my webspace right now, so lets see if attaching works
When I opened it up I was greeted with some pretty gnarly work around the RCAs, I've since cleaned it up and revealed a few pads that that I think once held a fuse.
There is still evidence of work being done elsewhere. Not sure what to make of that. I can only assume its ok since I don't have a good schematic for the ZR360.
I pulled a few of the suspect TIP35Cs to confirm that the one was shorted
Ok Finally got my webspace sorted out and was able to upload again.
So this is what I was greeted to on the bottom side of the PCB
there was a glob of solder connecting a couple points on the capacitors above. You can see the wire globbed in to replace what I think was a fuse
Cleaned up the mess, the solder glob was messy but harmless since they were on the same trace
This is where I think a fuse is supposed to go, on those pads
It appears as someone did work here, no idea if these are the original or even correct components
And just a overview of the board with 2 of the TIP35Cs removed. One is dead shorted.
Ok, So I got all the parts in the mail today. Installed tonight.
I have to upload pictures soon. I'm pretty happy with how it turned out.
Happy to report that this amplifier is back alive.
Perhaps its because I have it on a car battery on the bench and a Head unit is being powered via a benchtop power supply, but this seems to have a odd hum to it even when nothing is being played. If I turn the gain almost as low as it goes it will mostly go away.
I tend to think this is because of how I have it setup right now, but if I'm wrong I'd rather repair while I still have it all accessible
- General Interest
- Car Audio
- Trying to revive a Kicker ZR360
