Rockford fosgate punch 75 TO-237-3 Transistors
Old 14th February 2018, 08:31 PM   #11
wg_ski is offline wg_ski  United States
There are one or two amp topologies where swapping out bipolar outputs for mosfets without circuit adjustment is possible. Amp in question is probably using CFP 's - for low voltage drop when the outputs clip. It will run the driver transistors at a higher quiescent current compared to BJT outputs, but require less of them at full drive. This trick only really works for modest size amps - if you try to scale it up to something big it will have problems. Those old RF amps aren't that big by today's standards.
Old 15th February 2018, 02:35 AM   #12
Life is an Enigma is offline Life is an Enigma  United States
Originally Posted by seankane View Post
I did read his post, but thanks for looking out.
I have used IRF540 and IRF9540 in these amps many times with no problems. The IRF540 is "N" channel used in the "NPN" location and IRF9540 are "P" channel used in the "PNP" location.
Example: IRF540 "N" channel will be used for 2N6487 "NPN"
Example: IRF9540 "P" channel will be used for 2N6490 "PNP"
Thats good to know but what I need is a sub for the 2N6728 & 2N5716 they are no longer available / obsolete. I think I found a sub for the 2N6728 that is a MPS751 in TO-92 package but I stiil need a sub for 2N5716.
Old 15th February 2018, 06:07 AM   #13
seankane is offline seankane  United States
seankane's Avatar
I misread your first post. I thought you were looking for outputs not drivers, my apologies.
The later models used D41D8 and D40D8. I stock those. If the pin out is right maybe they will work.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 16th February 2018, 04:33 AM   #14
I thought D40D series TO-202's were just as much unobtainum as those funny looking TO 92-ish things. Even the tall 1 watt To92 is pretty well gone. Could use KSA1120/KSC2690.... while you can still get 'em.
Old 16th February 2018, 06:16 PM   #15
Perry Babin is offline Perry Babin  United States
It's odd that all of the drivers would fail. Are you sure that you need to replace them? Sometimes subs can cause problems.
Old 17th February 2018, 12:04 AM   #16
I just pick up the Punch 75 tested it distorted outputs opened it up and found the fuses wrapped in tinfoil I guess they thought it would work better that way
Old 17th February 2018, 02:37 AM   #17
Before replacing the fuses, squeeze the fuse holders together to ensure that they're tight.
Old 18th February 2018, 08:10 PM   #18
seankane's Avatar
You can still find them, their just expensive. I stock many of each.
Rockford fosgate punch 75 TO-237-3 TransistorsHide this!Advertise here!
Rockford Fosgate Punch 150 HD mike49504 Car Audio 5 9th January 2017 05:22 PM
Rockford Fosgate Punch 400.4 S Merlington Car Audio 19 4th February 2016 12:58 AM
Old rockford fosgate punch 150 chipper Car Audio 13 22nd March 2014 02:11 PM
Rockford Fosgate Punch 30HD Transistors rjadriscoll Car Audio 9 13th March 2013 03:58 AM
Rockford Fosgate Punch 200 IX S Merlington Car Audio 15 2nd September 2012 06:13 AM
