fosgate 55.2 wont power up
Old 26th February 2018, 11:30 PM   #21
seankane is offline seankane  United States
seankane's Avatar
If you had 540N to match, no do not use those. Order IRF9540.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 27th February 2018, 04:16 AM   #22
Theophili is offline Theophili  United States
I do also have some 540n's
Old 28th February 2018, 05:03 PM   #23
i think i might have a bad bridge rectifier (U1620R) how would i check this component with my dmm?
Old 28th February 2018, 05:31 PM   #24
i get .430v one way and with leads reversed i read .920v so im pretty sure the rectifier is bad
Old 28th February 2018, 10:03 PM   #25
Perry Babin is offline Perry Babin  United States
Is this out of the circuit?
Not a bridge rectifier. It's a dual rectifier with a center tap. A bridge rectifier has 4 diodes.
Old 28th February 2018, 11:55 PM   #26
yes it is still in circuit. after closer reading on your site perry i belive it to in fact be ok. another question, i have two output fets that test defective in circuit but test ok out of circuit?
Old 1st March 2018, 12:51 AM   #27
Testing in the board isn't definitive. Other components can make readings unusable.
fosgate 55.2 wont power upHide this!Advertise here!
Yamaha M-65 wont power on Rob B Solid State 11 20th March 2013 12:27 AM
Rockford Fosgate T20001BD wont power up amp it up Car Audio 10 23rd January 2013 04:26 PM
Rockford Fosgate P1000 Amp Wont Power On? stockz Car Audio 3 13th January 2013 10:23 PM
Rockford Fosgate punch p500-2 wont power on ivkata Car Audio 9 6th November 2012 04:15 AM
Amp wont power on, just keeps blinking, help! Mach1Chris Car Audio 7 4th May 2005 02:49 PM
