Diode ID help please
Old 6th February 2018, 04:16 PM   #1
Jeff Mills is offline Jeff Mills
Default Diode ID help please
Are DP3 & DP4 hanging off pins 9 & 10 of the TL494 4148's (switching diode) or are they Zener diodes?
In suspect 4148 but If they are Zener's, how do I check what value they are? There are no markings - I even checked with my magnifying glass.
Old 6th February 2018, 04:35 PM   #2
MarioRestucci is offline MarioRestucci  Italy
SURELY 100% 1n4148.
Typical configuration, 1n4148 in parallel at base and emitter of a bjt to turn on the mosfet.
Old 6th February 2018, 05:39 PM   #3
Diode ID help pleaseHide this!Advertise here!
Mosfet with inverted parallel diode or zener diode nonprof Car Audio 4 23rd October 2015 04:18 AM
old diode lucylu Power Supplies 1 11th June 2015 01:26 PM
Parallel diode vs antiparallel diode phieuxuatkho Class D 6 31st October 2010 01:54 PM
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 11:16 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 10:18 AM
