Making car amplifier SMPS with tl494 + DC Protection - Page 4 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 30th April 2004, 12:46 AM   #31
Grucho is offline Grucho  Croatia
Send a message via AIM to Grucho Send a message via MSN to Grucho Send a message via Yahoo to Grucho
Originally posted by himanshuraval
hi all of you,
I built that smps but both the mosfet are buz11 and it is heated very much and the smps is taking 7amp. to 9amp. without any load at output power so please hint about it
Check gate resistors ! I have one time placed to gate of one mosfet wrong resistor and I haved similar problem .
Old 30th April 2004, 01:09 AM   #32
Tensop is offline Tensop  Lebanon
a coupler cap between 12v input and the centretap on the primary side, care to explain in more detail?
Old 30th April 2004, 07:22 AM   #33
himanshuraval's Avatar
hi grucho,
i have used 100ohms at all four mosfet and my toroid's core size is 35mm(outer dia)x15mm(hight) and winding is 4x4 pri. 12x12 sec.turns but buz11 is heatiing within 5 seconds
Old 30th April 2004, 07:27 AM   #34
hi risto,
please what is your core size and winding data with wire gauge wich you used with your this smps
Old 30th April 2004, 03:45 PM   #35
tico70 is offline tico70  Costa Rica
himanshuraval,
Just a question, are you using a heatsink for the mosfets?
I am using the following circuit and it work perfectly. I am still working with two types of cores (toroid and ETD39)...for now the toroid is performing better and much easier to wind..
Old 30th April 2004, 06:39 PM   #36
Hi.
Remove transformer, and check mosfets, they should be cold when smps is runing.
I run my smps mosfets without heatsink, and they are cold under small load.
Current without load is from 100mA-500mA.
hi grucho,
Old 3rd May 2004, 07:17 AM   #37
Hi.
hi grucho
wich schematic do you use please and please send with pcb if you have layout
Old 3rd May 2004, 09:20 AM   #38
Tico70:
How to winding the transformer? How many turns have you used for primary and secondary?
TIA.
Old 3rd May 2004, 03:22 PM   #39
Originally posted by powerp
Tico70:
TIA.
hi powerp,
my troroid core size is 45mm(outer dia) x 10mm and winding is pri:4x4 turns and sec: 12x12turns
Old 3rd May 2004, 03:34 PM   #40
Hi.
hi grucho
i have removed transformer and check mosfet that is properly working and no consupt currunt but i removed first secondry of transformer and check and thats no consupt current but when i connect the dc circuit the circuit take much current and then after i removed power caps of dc output smps is running with about 900ma to 1amp. without any load at dc output
Overcurrent, overheat and overvoltage protection for TL494 Janez Power Supplies 17 21st December 2007 03:36 PM
Copyright 1999-2017 diyAudio
