Making car amplifier SMPS with tl494 + DC Protection
Old 12th September 2008, 03:32 PM   #531
luka is offline luka  Slovenia
luka's Avatar
I hope you can get IRFZ44's instead of BUZ... For Diodes, try MUR15xx
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 12th September 2008, 03:44 PM   #532
metal is offline metal
metal's Avatar
I 'll see tomorrow then.
Old 12th September 2008, 03:51 PM   #533
luka's Avatar
Originally posted by metal
Now I will use your schematic for the car SMPS. What wire gauge did u use and how many wires did u twist together for the primary and secondary as well as # of turns to get 40V on each rail, I do care about ur primary winding as it's most important in this case, then secondary can be calculated.
Another thing on mind, can I use those diodes in the ATX power supply.
For primary and secondary I used 1mm wire, it is not too small nor too big. You can check on internet how much current it can conduct and || so that current will be higher then one going into converter.
I FEEL SLOVENIA
Old 12th September 2008, 09:18 PM   #534
metal's Avatar
Thank you Luka. Did u use 8 or 10 turns with a center tap for the primary. Is it only one wire for the primary, or u twisted more than one wire.
Old 12th September 2008, 11:38 PM   #535
luka's Avatar
Hi
each primary has 6 turns, that is because I have unregulated supply. 4 would be used for regulated, but it is hard to spread them on whole core. Also number of primary wires depend on current, I used hmmm 6-8 wires for each primary? I don't remember, I would need to check. All I know is, it can handle a lot of current
I FEEL SLOVENIA
Old 7th November 2008, 10:06 PM   #536
arunkollam is offline arunkollam  India
Default Re: Commentable Thoughts
Originally posted by Workhorse
Hi Guys
I have made an amp + smps for my Contessa Classic car.
The smps uses
SG3525 PWM IC
12 X IRFZ44N mosfets
12 X 47ohm Gate resistors
1 X E-I CRGO 4 No. Iron Core Transformer :Primary=12-0-12 Multifillar Winding and Secondary 50-0-50 Windings.
one Vero board
2 X 100mFd 25V Caps
2 X 0.1mfd 50V ceramics cap
Couple of other resistors and caps etc.
Frequency is 250Hz
No - Feedback is applied , therefore efficiency is high.
1 X 3.5mFd/250V cap is directly connected to secondary of transformer to suppress spikes.
2 X small heat sinks.
Now the results
No heating on full load only simple warming of sinks
650W power capability
Still alives and is breathing in my car
IF any one interseted mail me.
Iam intrested in ur SMPS.plz mail me ur scematic and other detail(including transformer construction,gauge size of copper wire,stack width of coreetc)advance thanks
Old 7th November 2008, 10:06 PM   #537
Hi Guys
The smps uses
SG3525 PWM IC
one Vero board
2 X 100mFd 25V Caps
Frequency is 250Hz
Now the results
Iam intrested in ur SMPS.plz mail me ur scematic and other detail(including transformer construction,gauge size of copper wire,stack width of coreetc)advance thanks..email me at arun9584@yahoo.com
Old 11th November 2008, 09:52 PM   #538
milad-k800 is offline milad-k800  Iran
Default problem with toroid core
hi to all...
i want to help me by luka and pery...
I have finished 2 project of my car amplifier
last project builded with ETD core and current project works with toroid core.
but now I have mistake with yhis core.here is some information of my design:
output voltage at 13.8 volt is +/-47.5 at 6A
core diameter is 44mm outter and 30mm inner
pri winding:5-5(5of1.15mmwires)
sec winding:17-17(3of0.8mmwires)
freq is 33khz
the core and wires gets hot under little load
can this core handle this power that i want?
please help me.
this is my picture of finished 2 channel car amplifier
Old 11th November 2008, 11:21 PM   #539
Perry Babin is offline Perry Babin  United States
Does the core heat up if the amp is at idle (no audio output)?
What is the core material?
If you don't know, where did you get the core?
What is the current draw at idle?
Old 12th November 2008, 09:25 AM   #540
luka's Avatar
Yes like Perry said, core must be the right material, for right application, I have used once some I don't know nothing about, and it got really hot at idle, coz of wrong material. Current draw should be pretty small <<5A.
If your winding is ok, which I assume it is or current draw would be huge now.
After you find this out, we will see where to go from here on
I FEEL SLOVENIA
Making car amplifier SMPS with tl494 + DC ProtectionHide this!Advertise here!
Overcurrent, overheat and overvoltage protection for TL494 Janez Power Supplies 17 21st December 2007 02:36 PM
Copyright ©1999-2017 diyAudio
