Rockford 100ix
Rockford 100ix
Old 3rd December 2017, 12:32 AM   #1
seankane is offline seankane  United States
seankane's Avatar
Default Rockford 100ix
This amp is PC-0695-C.1
It came in with 2 shorted outputs in the 2 series channel.
I replace all 4 in the channel, all gate resistors and source resistors tested fine.
Power up the amp it draws 40amps current. If I remove Q243 and Q246 the amp powers and idles fine but R257 gets smoking hot because of the rail dc on the output terminal.
I only have 13.50vdc on the source pad of these 2 outputs. I should see full rail voltage.
I have +31.92vdc with these 2 outputs removed on the bridging terminal of the 2 series channel.
Anybody have any ideas?
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 3rd December 2017, 12:49 AM   #2
Perry Babin is offline Perry Babin  United States
What's the resistance from the negative rail to the source pads?
Old 4th December 2017, 04:44 PM   #3
seankane's Avatar
18.32M ohms from all 3 legs of 1610R same reading.
Old 4th December 2017, 08:36 PM   #4
Use a jumper wire to make a temporary connection to the outputs to see if that solves your problem.
Old 4th December 2017, 10:18 PM   #5
seankane's Avatar
Jumper from leg 2 "center" of rectifier to any of the source pads of the 2 FET's?
Old 4th December 2017, 11:01 PM   #6
Yes. They should be directly connected.
Old 5th December 2017, 11:56 PM   #7
seankane's Avatar
This brought the current draw down to 20 amps then instantly smokes R270 because it get rail across it.
The amp idles fine once R270 blows but still had the full rail on output terminal.
Old 8th December 2017, 04:00 AM   #8
If you have the tutorial, read the repairnotesp200dsm.htm page. It shows the parts that fail on the driver boards and give the part numbers for the IX boards. These amps are very complex and can have a lot of parts fail.
Old 8th December 2017, 04:56 AM   #9
seankane's Avatar
I only saw the 200 dsm didn't see anything for the ix amp
Old 8th December 2017, 04:58 AM   #10
read carefully
Rockford 100ixHide this!Advertise here!
Vintage Punch 100ix noise chasing judah304 Car Audio 4 15th August 2017 12:33 PM
Rockford Punch 100ix seankane Car Audio 80 22nd October 2011 07:50 AM
Rockford Punch 100ix seankane Car Audio 104 30th March 2011 03:08 PM
NOISE on audio system (Rockford 500a2, Sony xec1000, rockford PA2) stoke Car Audio 6 1st October 2010 10:21 PM
