Help New Guy (Rockville RXA T1 Car Amp)
Old 6th December 2017, 05:55 PM   #31
Jeff Mills is offline Jeff Mills
Originally Posted by kevinkr View Post
They might be 2N6055C darlingtons, I can't imagine their use in an automotive amplifier claiming that power level. I can't imagine an automotive amp could produce that much power in a package of that size or cost.
References to YPI semiconductors appear on the web, I would not click the associated links as they appear bogus.
The amp costs about $70 retail so I would not spend much on an attempt to repair it.
Sorry Kevin i must have overlooked your response - sorry about that. Rockville car / marine amps are not bad. They are not the best out there but not the worst either. But for the price they are hard to beat. Most of their amps / speakers have three ratings Peak / RMS / CEA for various speaker loads.
For example this 1500 watt 2 channel has the following specs:
Rockville RXM-T1 1500 Watt Peak / 750 Watt RMS Marine 2 Channel Amplifier
CEA Compliant Power Ratings:
250 Watts (2 x 125 Watts) at 4 ohms and 1% THD+N
370 Watts (2 x 185 Watts) at 2 ohms < 1% THD
1 x 370 Watts bridged @ 4 Ohms < 1% THD
RMS Power Ratings:
750 Watts (2 x 375 Watts RMS) @ 2 ohms
1 x 750 Watts @ 4 ohm Bridged Mono
500 Watts (2 x 250 Watts RMS @ 4 ohms) < 1% THD
Peak Power:
1500 Watts (2 x 750 @ 2 ohms or 1 x 1500 @ 4 Ohms)
I always go by the CEA ratings for amps/speakers since it's the closest realistic rating you can get. Problem is a lot of manufacturers don't include CEA ratings for their gear.
BTW - I have Rockville's RXM-S6 Marine/Boat 6 Channel Amplifier bolted to the back wall behind the rear seat in my pickup. It's powering 12 8ohm door speakers, plus 2 dual 4ohm voice coil 10" subwoofers. If I get on it, it's so freaking loud it makes my eyes water, rattles my teeth and makes my nose itch. Not to say all mirrors are rendered useless. I really enjoy the clear A/B sound the RXM-6X produces and it's given me absolutely zero problems so far.
Have a look see -->Rockville RXM-S6 Marine/Boat 6 Channel Amplifier 2600 Watt Peak / 1300w RMS - Rockville Audio
Anyways I hope that helps???
Old 1st January 2018, 05:29 PM   #32
Well I replaced channel 1 output transistors along with a few resistors. I also replaced all of the power supply transistors with IRF3205s. I then hooked it up to a 12v power supply with a 5watt fuse, did a little probing. I thought everything looked good... I even played it about 15 mins on the test bench.
I then reinstalled it back in my truck and after about 10 mins of playing the power supply bank burnt out
I know for sure I didn't have any solder bridges - now I'm lost on where to start over.
Old 1st January 2018, 05:55 PM   #33
Perry Babin is offline Perry Babin  United States
I don't know you you posted the last image but clicking on it after typing part of a reply will cause the loss of everything typed. Please use the 'Go Advanced' and "Manage Attachments' option to post images.
Did you check/replace the driver transistors?
Old 2nd January 2018, 03:01 AM   #34
Attachment 654089
I reattached the picture. I just replace all of channel 1 and both banks of power supply transistors. A few resistors we're also open and needed to be replaced.
Old 2nd January 2018, 04:15 AM   #35
Re-read post #12
Old 3rd January 2018, 04:41 PM   #36
Originally Posted by Perry Babin View Post
Re-read post #12
Thanks Perry!
Anyone know where I can purchase a pair of MUR1220CT/MUR1220CTR or substitutes?
Old 3rd January 2018, 06:13 PM   #37
Are the rectifiers defective?
Old 4th January 2018, 02:25 AM   #38
Yes sad to say I also checked / re-flowed solder joints D23/24. I also tested both outputs (A1266) one is shorted.
Old 4th January 2018, 02:51 AM   #39
Did you check them out of the board? It's very rare to see rectifiers fail in an amp like this.
MUR1620CTRG ON Semiconductor | Discrete Semiconductor Products | DigiKey
MUR1620CTG ON Semiconductor | Discrete Semiconductor Products | DigiKey
Old 5th January 2018, 12:02 AM   #40
Hi Perry no not yet but I will... New symptom though I hope you can help me with. Even with the remote wire unhooked the negative side of the bank of 3 PS transistors heat up / snap / crackle / pop / burn up. They are IRF3205 with 47 ohm resistor on the gate. The positive side is fine.
I have not replace the two outputs yet A1266 - waiting for them to come in.
Help New Guy (Rockville RXA T1 Car Amp)Hide this!Advertise here!
Rockville 18'' Box Build 30hz? carlk5555 Subwoofers 9 1st March 2016 12:55 AM
Rockville Reviews Granta53 PA Systems 6 20th July 2015 04:32 PM
