DC AUDIO D9
DC AUDIO D9
Old 27th November 2017, 05:38 PM   #1
megael9 is offline megael9
DC AUDIO D9
Default DC AUDIO D9
This amp came to me with 4 shortened output mosfets, and a damaged driver board.
I replaced the 4 mosfets and driver board with brand new board. I also
pulled out all the rectifiers to power the amp On, and it powered without any problems, how ever, when I test the signals at the gate of the output mosfets nothing shows. Do I need to have the rectifiers solder back In to get a signal at the output gates?
fluke 50 mhz scope,35 amp power supply,0.5-12v adj power supply, fluke 179,hot air desolder gun, merit multyfuntion signal tracer/generator.
Old 27th November 2017, 09:15 PM   #2
Bertje is offline Bertje  Netherlands
Only 4 mosfets replaced? I replace each group, when they are in parallel. And use MOSFETS from the same factory badge.
Old 27th November 2017, 10:41 PM   #3
Perry Babin is offline Perry Babin  United States
Do you see the test signal at the input to the driver board?
If so, have you connected a 10k resistor from pin 1 to pin 2 of the TL072 to see if the TL072 produces clean audio?
Old 27th November 2017, 11:52 PM   #4
DC AUDIO D9
No, no signa present at driver board input.
Old 28th November 2017, 12:08 AM   #5
You'll have to find the reason that you don't have audio reaching the driver board.
Old 28th November 2017, 02:36 AM   #6
DC AUDIO D9
No reason why I had no signal was because R167 had one leg lifted of the board. Now I have signal at the driver board input pin, but no signal coming out of the driver board output pins.
Old 28th November 2017, 03:09 AM   #7
seankane is offline seankane  United States
seankane's Avatar
Maybe something on the new driver board is defective?
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 28th November 2017, 03:31 AM   #8
DC AUDIO D9
Originally Posted by megael9 View Post
The reason why I had no signal was because R167 had one leg lifted of the board. Now I have signal at the driver board input pin, but no signal coming out of the driver board output pins.
Old 28th November 2017, 04:20 AM   #9
DC AUDIO D9
I replaced the driver board with a good tested board, and no charges.
Signal goes in, but don't come out.
Old 28th November 2017, 04:27 AM   #10
seankane's Avatar
Could there be a damaged via on the main board where the driver board solders on?
DC AUDIO D9Hide this!Advertise here!
Multi player for pc to play multiple audio files via digigram audio card TJSentech PC Based 1 24th October 2017 05:30 AM
New Freeware PC VST Audio Plugin: Ixahe Audio - MyLim Ixahe PC Based 13 19th July 2016 12:07 AM
JL Audio 300/4 Low Audio Output Troubleshooting Tip kds9591 Car Audio 3 25th December 2012 02:09 PM
Good books or videos on audio production, audio engineering, or audio editing tunks14 Everything Else 0 15th April 2011 11:00 PM
For Sale Or Trade: Adire Audio Brahma, Rythmik Audio Plate Amp tmort Swap Meet 5 27th June 2009 01:29 AM
