DC AUDIO D9
DC AUDIO D9
Old 28th November 2017, 04:57 AM   #11
Perry Babin is offline Perry Babin  United States
Have you connected a 10k resistor from pin 1 to pin 2 of the TL072 to see if the TL072 produces clean audio?
Old 29th November 2017, 02:55 AM   #12
megael9 is offline megael9
DC AUDIO D9
No, there's no signal with the 10k resistor in place, but again I lost signal at driver board input pin.
All regulators -15; +15; -5 and + 5 are all ok.
Pin 1, 7, and 8 of IC 102 have signal, but there's no signal coming out of pin 14, so
I replaced IC102 (TL074) and no good result. Any idea?
fluke 50 mhz scope,35 amp power supply,0.5-12v adj power supply, fluke 179,hot air desolder gun, merit multyfuntion signal tracer/generator.
Old 30th November 2017, 04:11 AM   #13
DC AUDIO D9
Without the rectifier there's no signal at the driver input pin, but with the rectifiers solder in
There is signal going into the driver board and signal on all 4 low sides out of the driver board. ls this normal for this amp?
Also I tried to force the high side signal out using 12 volts between pin 11 and 13, but could not get the high signal to come out.
Old 30th November 2017, 05:22 AM   #14
How far did the signal go when the rectifiers were out?
Old 30th November 2017, 04:10 PM   #15
DC AUDIO D9
I couldn't trace it back to far, but with the rectifier out, the signal doesn't make it to the driver boar input pin.
The signal goes as fallow.
IC 101, pin 1 and pin 7 good signal same amplitude , pin 8 good signal some amplitude, pin pin 14 good signal some more amplitude.
IC202 pin 1 or 7 no signal.
IC203 signal is coming out at pin 1 with clipping at the button, and pin 7 with clipping at the top.
IC102 pin 1, 7 and 8 good signal same amplitude. Pin 8 no signal.
IC103 pin 1, 7 and 8 good signal same amplitude, pin 8 good signal some amplitude.
Old 1st December 2017, 04:48 AM   #16
DC AUDIO D9
Does DC audio sell schematic for their amps?
Old 1st December 2017, 06:29 AM   #17
There is a resistor feeding the signal from an op-amp to the driver board. Did you lose signal on the side of the resistor that was not connected to the driver board?
Old 1st December 2017, 01:43 PM   #18
DC AUDIO D9
There's no signal at neither side of that resistor.
Old 4th December 2017, 12:48 AM   #19
DC AUDIO D9
A customer brought me another identical model amp with a bad power supply, so a repaired the power supply and tested the amp. After it was tested and working, I took the rectifiers out and test the signal at the driver board input, and to my surprise, there was no signal.
I Don't know why, but this amp can not be tested without rectifier in the circuit.
I'd put back together the original amp that was giving me problems, and it was working perfectly.
In the past, I tested very similar amps without the rectifier soldered in and got good result, but not these D9.
Does anybody knows why this amp can not be test it without the rectifier in the circuit? Thank you for all the help.
Old 4th December 2017, 04:53 AM   #20
I can't see any reason if you have all supply voltages except rails with the rectifiers out.
DC AUDIO D9Hide this!Advertise here!
Multi player for pc to play multiple audio files via digigram audio card TJSentech PC Based 1 24th October 2017 04:30 AM
New Freeware PC VST Audio Plugin: Ixahe Audio - MyLim Ixahe PC Based 13 18th July 2016 11:07 PM
JL Audio 300/4 Low Audio Output Troubleshooting Tip kds9591 Car Audio 3 25th December 2012 01:09 PM
Good books or videos on audio production, audio engineering, or audio editing tunks14 Everything Else 0 15th April 2011 10:00 PM
For Sale Or Trade: Adire Audio Brahma, Rythmik Audio Plate Amp tmort Swap Meet 5 27th June 2009 12:29 AM
