Dear all,
I got this amp for repair. It is missing two diodes on the board. If anybody can help me with the details will be very helpful. I want to know what is D305 and D306. Picture attached.
The diode is just like a glass. I applied some white compound and then tried to see after rubbing it little bit. But that have no number. I am attaching the picture of diode.
The resistors could be part of the RC zobel network. If so, the resistor will connect to one of the caps and the other side of the cap to the other speaker terminal (or secondary ground) for each channel. The resistors would likely be about 4.7 ohms.
