Alpine 3545 blows all fuses after 5 seconds of power
Old 4th December 2017, 10:41 PM   #81
bmore5077 is offline bmore5077  United States
Does anyone know how close the transistor pairs should be. Above when I tested leg 3 of the npn and pnp transistors there was 3 pairs and they read 1.0, 1.1 and 1.3mv. Is that close enough or about how close should they be. Thanks
Old 4th December 2017, 10:44 PM   #82
Perry Babin is offline Perry Babin  United States
If you went back through, did those numbers remain the same for all 3?
Old 4th December 2017, 10:55 PM   #83
After 20 min the bad side. 1st pair went from 1.1 to 1.7 second pair went from 1.3 to 1.9mv. Thanks
Old 4th December 2017, 11:00 PM   #84
After the temperature stabilizes, if they're about the same across all 2/3 pairs, I think it's OK. For tests to see if current sharing is good for all transistors, it's better to test with a sine wave at higher power into a load. If you use all matching parts from the same batch and the emitter resistors are within tolerance, it's likely OK. It's not something to really worry about. The initial tests where the bias went to 7.whatever mv was what concerned me initially. All appears OK for now.
Old 4th December 2017, 11:24 PM   #85
Thanks again. So I guess I'll let it warm up at the 1 mv you had me set it at and then set it to 4mv from the testpoint as the service manual states. Thanks
Old 4th December 2017, 11:59 PM   #86
4mv is too high, in my opinion. I'd leave it around 1mv.
Old 5th December 2017, 12:17 AM   #87
Ok sounds good. Thanks
Old 13th December 2017, 08:41 PM   #88
Ok so I replaced the non and pnp transistors on the one channel and adjusted both to 1mv idle current but the one repaired channel still plays much lower than the other. Not sure what's going on. Thanks
Old 13th December 2017, 08:51 PM   #89
Actually it starts off louder than it cuts it down. Maybe thermal but not sure
Old 13th December 2017, 11:07 PM   #90
That sounds like a preamp problem. Check the signal level for both channels where the preamp signal goes into the main board.
Alpine 3545 blows all fuses after 5 seconds of powerHide this!Advertise here!
PSU Smoothing caps change, Now 1 of the internal fuses blows on power up, help :-o Deaf Cat Power Supplies 6 11th April 2015 11:45 AM
Alpine 3545 off/on/fizzle out AcuraTLSQ Car Audio 10 8th August 2014 03:48 AM
alpine 3545 79silverta Car Audio 1 17th June 2014 06:44 PM
Alpine 3545 power supply noise Dr Zeus Car Audio 16 20th December 2010 12:34 AM
Power Acoustik TS980 sparks, blows fuses even without power on. BoeroBoy Car Audio 7 30th September 2010 03:17 PM
