remove c10 without problem, the voltages remain the same, what if you notice, is when I make the bridge between leg # 18 and pad # 18 the voltage has up to 23 volts for a fraction of a second and then voltage drops to 10, this change of voltages It also happens in regulators.
pad # 18 without C10 has 5.55 volts
leg #18 5.0 volts
leg #18 5.0 volts
- General Interest
- Car Audio
- rockford fosgate T5002 problem
