Audison SRX
Audison SRX
Old 28th November 2017, 09:00 AM   #11
MarioRestucci is offline MarioRestucci  Italy
MarioRestucci's Avatar
Originally Posted by NadaD View Post
Well, I will try it later.
Also i tried to load transformer with few fets.
I dont know how to explain easier, but when there is installed only 2 fets - it works OK, draws about 400mA. Current increases as I install more fets.
make sure if the squarewave is present and identical on ALL gate pad.
Old 28th November 2017, 09:11 AM   #12
NadaD is offline NadaD
It is, all fets have drive signal as shown before.
Old 28th November 2017, 09:53 AM   #13
if it is, then, you have counterfeit fets.
it's also possible that your 3525 is defect, but very unlikely.
Old 28th November 2017, 10:46 AM   #14
Doubt it, originals were bought from Farnell.
Old 28th November 2017, 12:51 PM   #15
can you make a photo of top and bottom of the board in trf/fets area?
Old 30th November 2017, 06:44 AM   #16
ppalli is offline ppalli  Italy
I hope this schematic may be usefull
Old 30th November 2017, 07:02 AM   #17
There is nothing else to add.
If the amplifier absorbs the right amount of current by installing only 2 MOSFETs (1 per bank) the problem may depend on faulty MOSFETs, MOSFETs too different from each other, pull down resistors or damaged gate resistors, damaged drivers or at maximum sg3525 does not work well (but it is unlikely).
If the scheme you have published is identical to your amplifier, with 10ohm gate resistors it is easy to encounter resistors that seemingly appear to be in the standard but which are actually damaged.
Also the driver stage could work well with a small load (1 MOSFET per bank) and cause problems when loading more (all MOSFETs installed).
In addition, R9 and R20 may look intact, but better controllable.
At the end of all these controls, if you still can not find the problem, try changing sg3525.
Make this tests always without rectifier.
Also D12 & D9 from the secondary winding must be removed during this test.
Old 4th December 2017, 04:39 PM   #18
Well, i have to check these old fets - I installed fresh irf3205 in place of these, and current stays low, no heating.
Audison SRXHide this!Advertise here!
SRx 1.d audison nonprof Car Audio 6 5th September 2017 11:32 PM
Audison help rrae Car Audio 26 7th February 2017 06:10 PM
Audison SRx1D nikb47 Car Audio 15 19th December 2013 12:28 PM
Audison srx rrae Car Audio 9 17th September 2013 12:07 PM
Audison LrX 6.9 Madmike2 Car Audio 0 6th April 2008 01:47 AM
