Cap replacement Soundstream D/MC series.
Old 10th November 2017, 03:42 AM   #1
doug71zt is offline doug71zt  Canada
Default Cap replacement Soundstream D/MC series.
I've got a number of older SS amps that I'm about to put into service after storage (15yrs). D100II, D200II, MC300, CA50II.
One of the D200II had blown outputs and a blown FED16BT dual diode. Not sure what was the cause and what was the effect on that one. I have the parts on the way to repair that.
My question is which caps should I consider replacing in these amps? Most are low hr units, none of the electrolytics are bulged or leaking.
Just the PS filter caps? What brand/series should I be using there (2200mf 50V)
Input caps or any in the signal path like the 10mf before the 3067 dual transistors?
Any input would be appreciated greatly.
Old 10th November 2017, 04:21 AM   #2
Perry Babin is offline Perry Babin  United States
Do you have a capacitance meter?
Sometimes the old caps are still within tolerance and sometimes you'll find a series of caps that tend to fail. I'm not a fan of replacing parts that don't need to be replaced.
Old 10th November 2017, 05:15 AM   #3
Hi Perry - I do not have a capacitance meter, I do have a Fluke 177 with a Cap function.
Don't the caps have to be removed from the circuit for a proper test?
Old 10th November 2017, 05:45 AM   #4
For most meters, they need to be out of the circuit.
Old 13th November 2017, 03:12 AM   #5
Thanks Perry, as I suspected..
It's a bit of a catch-22, you have to de-solder them to check, so why not replace them instead....same amount of labour.
The MC300 has had the electrolytics replaced in two channels but not the other two, everything else is untouched. I am the second owner of the MC300 so don't know what sort of life it had, it has been worked on by a pro shop at least once, dual diodes and switches have been replaced already.
What are the recommended capacitors for power supply filter caps? Caps in the audio circuits?
Thanks Doug
Old 14th November 2017, 06:51 AM   #6
You would only have to remove a random sample.
It sounds like you're going to replace them, for no good reason. Millions of perfectly good capacitors have been replaced for the exact same reason. A good technician replaces the parts that need to be replaced.
Old 14th November 2017, 09:52 PM   #7
phase is offline phase  United States
I actually stared at the ones in my D200IIs for a couple days before deciding they were meant to stay. They are excellent quality Nichicon, with very nicely sealed ends...
I did replace the smaller ones on the feedback section with some slightly smoother sounding parts.
Could have just left it all and probably would have been just fine for reliability, was trying to get it to sound closer to the other amp I was using with it.
Old 15th November 2017, 03:08 AM   #8
Ok, I'm going to leave them as-is until I get them in a system and listen to them.
Doug
Old 17th November 2017, 10:11 PM   #9
Any idea where I can get replacement FETs for the power supply? The show as P25N06 on the schematic.
Digikey shows them as obsolete.
Old 17th November 2017, 10:44 PM   #10
With 47.5 ohm gate resistors, you can use a variety of FETs. The IRFZ44 should be OK.
You may need to replace the 150 ohm pulldown resistors with 100 ohm so order those as well.
Cap replacement Soundstream D/MC series.Hide this!Advertise here!
Replacement of MPSA14 for soundstream amp nonprof Car Audio 2 17th December 2014 08:04 AM
soundstream reference 6.0 class A help with suitable replacement russdeanlee Car Audio 2 10th February 2013 10:06 PM
soundstream reference 414 driver card rebuild or possible replacement ivkata Car Audio 6 15th April 2012 07:43 PM
soundstream reference feb board replacement russdeanlee Car Audio 8 16th March 2012 11:46 AM
Coupling cap replacement in series? TechnoBeaver Tubes / Valves 8 8th November 2010 01:33 AM
