MTX Thunder 2300 board photographs needed
Old 9th November 2017, 04:28 PM   #11
JonFennell is offline JonFennell
OK, the layout is now clear. Those two resistors in your last pic. Is that
Red
Red
Black
Gold
22ohms?
Nakamichi MB-100, MTX Thunder 2300, Soundstream 405s, Diamond Audio 12" Twin Voice Coil. Just need some decent components!
Old 9th November 2017, 04:37 PM   #12
Perry Babin is offline Perry Babin  United States
22.1
22 IS CLOSE ENOUGH.
Old 9th November 2017, 05:04 PM   #13
How do you get 22.1? I'm missing something with these five band resistors I think.
Ok, all parts ordered. Thanks for the help, I will be back shortly for a final check before fireup.
Old 9th November 2017, 05:36 PM   #14
red red brown gold brown
221/10 1%
Old 10th November 2017, 08:41 AM   #15
Ah OK. I understand now.
Final issue. Previously I removed the diodes. Should I replace them and which way round do they go, and are there better replacements out there now?
Old 10th November 2017, 08:56 AM   #16
Aha, I found you previously suggested these for the rect:
'The FETs and rectifiers can be purchased from Digi-key or mouser (among others). I'd use the IRF3205 for the FETs. Order the MUR1620CT and MUR1620CTR for the rectifiers '
So I will order these.
Old 10th November 2017, 09:00 AM   #17
Dammit, I can only get 1620CTG and 1620 CTRG.
Are these the modern equivalent?
Old 10th November 2017, 09:03 AM   #18
G indicates lead free. Otherwise, equal.
Old 10th November 2017, 01:01 PM   #19
Hi Perry, thanks for that. The diodes test OK. Do you have a picture that shows which is which? Rect 1 and Rect 2?
I'm going to fire this up using a headlight bulb as current regulator. Wish me luck!
Old 10th November 2017, 01:04 PM   #20
Does one rectifier read 0 ohms from the B+ terminal to the outer pads for the rectifier?
MTX Thunder 2300 board photographs neededHide this!Advertise here!
MTx Thunder 2300 X Jason Smith 616 Car Audio 3 20th November 2016 11:11 AM
MTX Thunder 2300 S Merlington Car Audio 2 5th April 2016 09:21 PM
mtx thunder 2300 fishingdave Car Audio 18 24th May 2014 12:42 AM
mtx thunder 2300 enthusiast123 Car Audio 9 25th April 2014 10:51 PM
MTX Thunder 2300 sreten89 Car Audio 4 13th April 2013 06:02 PM
