Another ir2184 base amp
Old 26th September 2017, 02:10 PM   #11
ian33 is offline ian33
Am seeing the same signal previously posted on these pins
Should there be positive rail voltage going to the driver board?
Old 26th September 2017, 06:06 PM   #12
Perry Babin is offline Perry Babin  United States
Do you have a clean sine wave coming out of the preamp section?
Old 6th November 2017, 02:33 AM   #13
I went back to this amp science i have two with the same driver board and similar problem.
I did not see a sine wave.I saw a square wave from the preamp section going to the driver board.
Old 6th November 2017, 10:02 AM   #14
Turn the signal level down. Does that give you a sine wave?
Old 6th November 2017, 01:16 PM   #15
Yes I see a sine Wave.
Old 6th November 2017, 06:42 PM   #16
Answer qthe questions here:
Old 7th November 2017, 02:49 AM   #17
Thats the same amp.
Should i disable the ICs and connect the 10k ohm resistor and check for signal again?
Old 7th November 2017, 01:40 PM   #18
I see signal on pin 1 of the 072.The bottom clips before the top if I increase the signal.I see a square wave on pin7 of U4.The scope does not lock on the signal but I can clearly see the square wave.on pin one of the driver ICs I see a square wave but they not identical with same scope setting.
Old 12th November 2017, 07:17 PM   #19
Would that indicate the driver ICs have fail?
Old 14th November 2017, 06:56 AM   #20
When checked as shown below, do you get very similar readings from all driver ICs?
Another ir2184 base ampHide this!Advertise here!
Need help with base. gurrkis Class D 4 20th September 2016 06:55 AM
IR2184/21844 Amp questions mbates14 Class D 0 21st November 2014 02:43 PM
base vs. bass scott17 Everything Else 56 5th May 2012 05:06 AM
What DO YOU base your next project /needs on ??? JinMTVT Multi-Way 21 17th November 2005 11:54 PM
base for amp karma Tubes / Valves 7 18th June 2004 03:03 AM
