You will have to invert the compressed air can. After replacing the resistors that burned, you will drip the compressed air onto all of the ICs in the class D section until they frost over. Power the amp up for as long as you can without the resistors burning. Do you see any IC that defrosts more quickly than the others?
Still trying to figure out which one is bad perr y I got all new led for the board, installed them. I tried finding which one of the isolators was bad using your freeze method. I am still burning out the resistor. I have changed u200, u203, same result. Am I looking at the wrong part perry?
- General Interest
- Car Audio
- Rockford T500-2bd help.
