Orion colbolt cb1200.1 puzzle.
Old 16th September 2017, 12:20 AM   #11
rhempz01 is offline rhempz01  United States
The board isn't the easiest thing to trace, its very cheap and badly soldered I had to repair alot of trace that was damaged due to heat.
Old 16th September 2017, 12:36 AM   #12
Perry Babin is offline Perry Babin  United States
Use your meter to find the 0 ohm connections. Gate resistor to any possible driver emitters.
Old 16th September 2017, 01:29 AM   #13
Yes, all I found were the 1am and 2a, on the power board with the 494, but it isn't powering up. Should I remove the outputs and deal with the power issurb? On the source there is 6.23v with no b+ remote and ground only
Old 16th September 2017, 01:33 AM   #14
Only Rockford amps can be used with only ground and remote for troubleshooting.
Old 16th September 2017, 01:45 AM   #15
Oh OK perry. How should I check it?
Old 16th September 2017, 02:10 AM   #16
If it won't power up normally, post the voltage on all pins of the power supply driver IC.
Old 8th February 2018, 03:02 PM   #17
I need to know what these the values of these resistors on an Orion 1200.1 rev.A they were to burnt to read the color codes. Can someone upload a picture of a healthy ps side of the board?
Old 8th February 2018, 05:52 PM   #18
This mess..
Old 8th February 2018, 11:45 PM   #19
ian33 is offline ian33
The original PS gate resistor is 10 ohms
Old 13th February 2018, 11:29 PM   #20
I don't know there designated placement on this board. I need to know what values go where on that side buy the ps fets. Along with the few other resistors as they were all burnt
Orion colbolt cb1200.1 puzzle.Hide this!Advertise here!
Help with an LED puzzle... calabash Instruments and Amps 6 10th March 2012 11:29 PM
Orion xtr-2250 Jigsaw puzzle please help! jordan_ciaramit Car Audio 23 23rd July 2011 05:01 AM
Orion NT 200 vs Orion 2150 SX Clipped Car Audio 3 12th June 2007 01:55 PM
help me with this puzzle... AudioGeek Tubes / Valves 3 21st May 2005 07:48 PM
Puzzle dhaen The Lounge 1 5th August 2004 01:00 AM
