Are the transistor tabs touching the clips?
I thought of that being a possibility. I will put the amp together again tomorrow and check it. I had bought mica strips at the local electronics store and made sure there was no contact between the transistors and heatsink but never looked to see if the clips were possibly touching. I will test and get back to you.
Thank you
What is the correct replacement for the power FETS? Would these be them
IRFZ44NPBF Infineon Technologies | Mouser
I also measured the surface mount resistors and they measure 47 ohm except for 2 each for each cheannel side. Two measure at 127 ohm and two at 47 ohm for each channel.
Is there a schematic floating around for this amp? If so it would be helpful since I feel like I am flying blind.
Thank you
Thank you
If the resistors read out of tolerance, they must be replaced.
I use IRF3205s for the power supply in this amp.
This is what I am not sure of? What is the tolerance for those resistors?
Right Channel
R308 & 309 read 127 ohm
R110 & 311 read 47 ohm
Left Channel
R408 & 409 read 127 ohm
R410 & 411 read 47 ohm
Should they read 47 ohm for all 8 resistors on the output side?
Thank you
Right Channel
Left Channel
Thank you
Disregard those the last post. Those are correct values. Verified that looking at the resistor value marked on them. I could not see them before
- General Interest
- Car Audio
- JL audio 300/2 low ohm shut off
