cadence xd1200d
cadence xd1200d
Old 23rd August 2017, 12:56 AM   #1
ian33 is offline ian33
Default cadence xd1200d
This amp has no output.Rail and regulated voltage ok. I don't see any oscillation on the outputs.When signal is applied the op-amp with the arrow will head up.I replace it no change.Any suggestion on this one?
http://i1231.photobucket.com/albums/...anks33/cad.jpg
http://i1231.photobucket.com/albums/...nks33/cad1.jpg
Old 23rd August 2017, 07:00 AM   #2
Perry Babin is offline Perry Babin  United States
Which of the opto-couplers has pin 3 directly connected to the secondary ground?
Old 23rd August 2017, 01:05 PM   #3
U304B It's the second one in the left watching from my pic
Old 23rd August 2017, 02:28 PM   #4
Monitor the voltage across pins 1 and 2 of that opto-coupler from the time you apply remote to about 15 seconds.
Do the same for pins 3 and 4.
Do you get a voltage change after the initial mute delay on both?
What is the voltage before and after the mute delay?
Old 23rd August 2017, 07:32 PM   #5
Pin 1and 2 during the delay is 0.025 and after is 1.115
Pin 3 and 4 during the delay 80v and after 0.162v
Old 23rd August 2017, 08:00 PM   #6
That's working correctly. When pin 4 goes to near ground, the output stage should be enabled and should begin to oscillate.
Bad solder connections could lead you to transistors that may have run too hot for too long and could be defective.
cadence xd1200dHide this!Advertise here!
Cadence CPA245 Frycztech Car Audio 19 22nd May 2017 06:34 PM
cadence ian33 Car Audio 23 28th September 2015 05:14 AM
Cadence SUB manoli337 Subwoofers 2 4th July 2012 08:18 PM
cadence amp hitman1 Car Audio 9 19th May 2011 06:33 AM
Cadence CXR400 Crossover mike49504 Car Audio 2 22nd September 2010 06:05 AM
