Ground zero GZPA 1.4000DXII
Hi, I have this Ground zero GZPA 1.4000DXII I need help identifying parts numbers for the IC's that are scratched off.
This amp had a blown power supply and output. I repaired the power supply, but I get no class d switching. I can hear light ticks from the output. Please help!
There is a test procedure that allows you to check for signal at various points. There are a few variations. The following thread is the procedure for a similar amp.
For most amps, you solder a 10k resistor between pins 1 and 2 of the TL072. Then you solder a bridge between legs 2 and 3 of the 21844. Driving a strong low frequency signal (50Hz-100Hz), if the circuit is working correctly, you will be able to see a square wave at the output of the TL072, at the output of the LM211 and at the input of the 21844.
Checking PWM signal on Class-D amps using IRS21844S problems
what is the function of the 10k resistor?
i've understand that the bridge between pin 2 & 3 of irs21844 force the chip to shutdown her output, but the resistor?
There is no feedback without the amp working normally. The open feedback loop can make the op-amp do strange things. The 10k feedback resistor allows the op-amp to function as an audio amplifier. If the output of the op-amp is clean audio, you can see that the op-amp is functioning normally and can move on to the next stage of troubleshooting.
thanks for the info.
