Rockford Fosgate M400-4D
Old 14th November 2017, 06:45 AM   #31
MarioRestucci is offline MarioRestucci  Italy
MarioRestucci's Avatar
To test your 7905 you can apply a 12v input, and without any other external component, you can check if you have 5volt output.
Anyway, I think it's unlikely 7905 defective.
Old 27th November 2017, 07:00 PM   #32
josesony68 is offline josesony68  Spain
josesony68's Avatar
7905 have been replaced by new ones.
In pin 10 of IRS2092S I have -26.83v measured with black tip in -B and red tip in pin 10.
Old 28th November 2017, 07:08 AM   #33
you must have 12/15v at this point.
Check VCC regulator!
The negative voltage that you have measured is because the vcc is obtained from negative rail.
7905 and 7805 are probably used to generate VAA and VSS that are respectively +5v and -5v.
Old 6th February 2018, 09:11 PM   #34
josesony68's Avatar
VCC regulator 7812 measured with black tip in B- are:
in: -11,4
ground: -26,7
out: -14.5
Now, measured with black tester tip in ground of the regulator I have:
in: 15.29v
out: 12,23v
I think this regulator is in perfect condition
Old 7th February 2018, 08:08 AM   #35
in: -11,4
ground: -26,7
out: -14.5
in: 15.29v
out: 12,23v
of course
Old 7th February 2018, 09:16 PM   #36
josesony68's Avatar
So, do you think I should think that all IRS2092S may have failed?
I think I should see a square waveform on pins 11 and 14 (to my mind) in the same way a triangular waveform on pin 4
I'm right?
Old 4th March 2018, 06:51 PM   #37
josesony68's Avatar
I keep spinning ...
I can not find the fault ...
In the end, I'll end up throwing the amplifier in the trash ..
Old 29th March 2018, 05:27 PM   #38
josesony68's Avatar
At last!
You were right, Mario
I replaced all the IRS2092 ICs and managed to see square waveform in my scope on all the gate pins of the output fet.
I tried the amplifier with audio, and perfect sound on all channels.
I do not know why my head did not understand that these IC'S could be in bad condition, I also thought it strange that the four had failed, but it was like that.
Thanks MarioRestucci for your help.
Big!!
Old 30th March 2018, 08:24 AM   #39
Probably, you had a problem with the regulated power lines (WHICH ARE IN COMMON WITH ALL IRS2092) which in one stroke damaged all ICs, then you solved the problem and then you had to replace ICs.
Perfect like that!
Rockford Fosgate M400-4DHide this!Advertise here!
rockford fosgate megael9 Car Audio 1 1st May 2017 06:28 PM
Rockford Fosgate BD15001 S Merlington Car Audio 4 14th December 2012 08:51 AM
Rockford fosgate 4.6 X mike49504 Car Audio 14 28th May 2011 03:35 PM
Rockford Fosgate dtisme Car Audio 1 5th October 2010 11:39 PM
Rockford Fosgate 1500bd mike49504 Car Audio 52 26th March 2010 02:46 AM
