Rockford Fosgate M400-4D
Old 11th October 2017, 05:43 PM   #21
josesony68 is offline josesony68  Spain
josesony68's Avatar
All right, Mario.
+ B and -B, are correct, are + 24.4V and -24.4V
I should investigate further, to see if any regulator is failing ...
Old 11th October 2017, 05:49 PM   #22
josesony68's Avatar
ian, is R769 4,72k?
Old 11th October 2017, 08:50 PM   #23
MarioRestucci is offline MarioRestucci  Italy
Originally Posted by josesony68 View Post
ian, is R769 4,72k?
Unfortunately I can not see very well.
I do not have an electric diagram to consult.
It seems to me that R769 is equal to R763 (10K), I say it because it seems to be connected to ZD701 and ZD702 respectively.
is a typical resistor + zener configuration, probably to stabilize a lower voltage.
Anyway, I seem to understand that this area is related to the power supply.
Your power supply works fine, so it makes no sense to go looking for something at that point.
Remember, you have a missing trimmer.
It may be useful to adjust the switching frequency fine (in relation to that channel).
If you can understand the value of the other trimmers, you can install a trimmer of the same value in the space where it is now missing.
As you solve the VCC problem, you need to be very careful, as that trimmer will need to be adjusted very well for the same switching frequency of the other channels.
Old 11th October 2017, 09:32 PM   #24
josesony68's Avatar
I have to keep investigating ..
What about the trimmer disappeared, I think it is so in this type of amplifiers, I have seen a picture on the web of a new amplifier identical to this, and this trimmer at that point, is not installed.
Old 12th October 2017, 02:37 AM   #25
ian33 is offline ian33
ian, is R769 4,72k?
Amp gone already.
There is no port in that location.
Old 12th November 2017, 08:58 PM   #26
josesony68's Avatar
Thank you ian , for the information.
I have continued to investigate and I have found, that at the exit of L7905, 14V are obtained ... they should be -5v, right?
Old 13th November 2017, 06:48 AM   #27
what is your reference point measuring this?
Old 13th November 2017, 07:09 AM   #28
josesony68's Avatar
the reference point is the central pin of L7905
Old 13th November 2017, 09:16 AM   #29
That's not right!
the central pin can be used as a reference only for positive voltage regulators.
L7905 is a negative voltage regulator, and the reference point must be taken to the first pin because its configuration is different from the positive regulators.
POSITIVE REGULATORS:
1. in 2. gnd 3. out
NEGATIVE REGULATORS:
1. gnd 2. in 3 out
Old 13th November 2017, 01:31 PM   #30
josesony68's Avatar
Ooops!
I had not fallen in that detail! I thought the configuration was the same for the 78xx and the 79xx
I'm sorry I screwed up
Anyway, I've noticed a small difference ..
When I do the voltage measurements, the power LED turns into the two colors red / blue, and yesterday when I removed the L7905 to check it, a light bulb lit on my head and I connected the amplifier without this piece, then the power LED it became only blue ...
I think I have to keep track of this path ...
I have ordered these regulators to send me ..
Rockford Fosgate M400-4DHide this!Advertise here!
rockford fosgate megael9 Car Audio 1 1st May 2017 06:28 PM
Rockford Fosgate BD15001 S Merlington Car Audio 4 14th December 2012 08:51 AM
Rockford fosgate 4.6 X mike49504 Car Audio 14 28th May 2011 03:35 PM
Rockford Fosgate dtisme Car Audio 1 5th October 2010 11:39 PM
Rockford Fosgate 1500bd mike49504 Car Audio 52 26th March 2010 02:46 AM
