Rockford Fosgate M400-4D
Old 10th October 2017, 04:21 PM   #11
josesony68 is offline josesony68  Spain
josesony68's Avatar
Rail tension is present (48.8v) in the two metallic strips that are observed in the photo, I suspect that B- is the longest strip, from there taking the negative tip of the multimeter in B-, and the positive in the drain of the FETS of the out stage are observed 25v and 48.8v respectively in each pair of FETS.
Pin 10 of each IRS2092 is -24.7V with the negative probe of the multimeter to the negative of the amplifier.
On pins 1 and 6 there are 4.58v and -5.38v respectively.
The power LED on the amplifier is shown in the two colors red / blue
Old 10th October 2017, 04:22 PM   #12
josesony68's Avatar
Old 10th October 2017, 04:56 PM   #13
josesony68's Avatar
I can not find the way to see square waveform out of the power supply ...
Old 10th October 2017, 06:57 PM   #14
MarioRestucci is offline MarioRestucci  Italy
Vcc on pins 10 must be measured with black probe on -b....
You must see 12v.
4.58v on Pin 1 maybe is wrong.
-b, +b, +/- preamp voltages, -/+5.6v must be measured with black probe on gnd (Central tap of secondary winding of transformer).
Old 10th October 2017, 07:13 PM   #15
josesony68's Avatar
on pin 10 measured with B- with probe black is 0v.
pin 1 preamp voltajes is 5.48v
Old 10th October 2017, 07:35 PM   #16
Maybe I explained myself wrong!
When I talked about pin 1, 6 and 10, I was referring to 4 irs2092S.
For this reason, on the pins 1 and 6 of all the IRS2092S there should be 5.6volt (with black probe on PIN 2 of all IRS2092S) instead, on all pins 10 (of all IRS2092S) there must be 12volt (with black probe on -B).
When I talked about "preamplifier voltages" i meant the DUAL voltage present on the preamplifier board that isn't SINGLE 12volt, but usually +/-12v (if are installed TL072) and you must see this on pin 4 and 8 of all op-amp (with black probe on pin 2 of all IRS2092S)
If u have big different voltages on pin 1 and 6 of all IRS2092S probably u have problems with this part of circuit or a defective IRS2092S.
If u have 0 volt on pin 10 of all IRS2092S (with black probe on -b) you have surely a bad regulator (and probably, this is the main cause of your issue).
Unfortunely, RF do not share schematics of this new amp model, so we have to arrange it.
Old 10th October 2017, 08:42 PM   #17
josesony68's Avatar
No, you have not explained wrong, maybe there is some point that I did not understand well ...
I've always been measuring pins 1, 6 and 10 on all four IRS2092s.
On pins 1 and 6 of all IRS2092 there is +/- 4.99v measured with the black probe on pin 2 (there is no difference in any IRS2092)
Pin 10 continues without voltage
What I do not understand is when you say:
When I talked about the "preamplifier voltages" I was referring to the DUAL voltage present on the preamplifier board that is not SINGLE 12volt, but usually +/- 12v (if TL072 is installed) and you should see this on pin 4 and 8 of all op -amp (with black probe on pin 2 of all IRS2092S)
Do you mean the preamplifier board that contains the operational circuits 4580?
Old 10th October 2017, 09:44 PM   #18
Yes of course! But at this point i think that the preamp board work correctly.
-B and +B (with black probe on Pin 2 of irs2092s ) are identical and symmetric?
I dont understand but I've read this:
can you explain me better?
Old 11th October 2017, 09:01 AM   #19
josesony68's Avatar
-B and +B (with black probe on Pin 2 of irs2092s ) are identical and symmetric, have a very small variation.
I was saying:
Taking the black probe of the multimeter in B-, and red probe of the multimeter in the central pin of a FET (for example, the first one to the left of the board) of audio output, I observe 25V and taking reading to the FET that is next to him I observe 48,8V.
These measurements are observed by each pair of FETS, ie looking at the board and watching the eight output FETS, if one has 25V the next has 48.8V the next 25V, the next 48.8V and so all
Old 11th October 2017, 10:41 AM   #20
I was saying:
Measuring the voltage between drain of fets and -b is wrong.
If you want, can measure +b and -b like this:
- black probe on pin2 of IRS2092S
- red probe on leg 2 of hi-side fet (now you must see +b= 48v)
- red probe on leg 3 of low-side fet (now you must see -b=-48v)
any little differences (decimal volts) it's not important/relevant.
So, if you have tested and no problems found, your primary problem is the absence of VCC.
Go backwards in the circuit and found the regulator or the part of circuit that provide to create VCC. If u can, share photos here!
Rockford Fosgate M400-4DHide this!Advertise here!
rockford fosgate megael9 Car Audio 1 1st May 2017 06:28 PM
Rockford Fosgate BD15001 S Merlington Car Audio 4 14th December 2012 08:51 AM
Rockford fosgate 4.6 X mike49504 Car Audio 14 28th May 2011 03:35 PM
Rockford Fosgate dtisme Car Audio 1 5th October 2010 11:39 PM
Rockford Fosgate 1500bd mike49504 Car Audio 52 26th March 2010 02:46 AM
