Xenon 11.5k amplifier output card driver
Old 15th August 2017, 04:34 PM   #11
jlind54 is offline jlind54  United States
Make sure the resistors near the driver card are all in spec. There are some 1ohm or 4.7ohm resistors that sometimes open with no visible damage. With one defective the outputs will continue to fail when powered up until replaced. Are you using a new driver card, or have you replaced the 21844's on that one?
Old 17th August 2017, 08:29 PM   #12
Tom7227 is offline Tom7227  United States
Tom7227's Avatar
Xenon 11.5k amplifier output card driver Send a message via AIM to Tom7227
Actually, the amp works. The owner was using it, but one side of the amp gets hot very quickly. With no speaker connected.
I just found one the 2 inductors, had one connection totally burned off the PCB, no electrical connection at all.
This is the side that was overheating, but I am pretty convinced the Mosfets (24N50) , were overheating.
Do you think the Mosfets would overheat if no connection to the inductor?
Old 18th August 2017, 12:29 AM   #13
Tom7227's Avatar
I will answer my own question.
The Mosfets overheated like mad before I fixed the inductor. The amp drew 104 amps idle, yet still functioned.
After repairing the inductor, amp is cool, and draws 22 amps idle.
Old 18th August 2017, 12:36 AM   #14
Perry Babin is offline Perry Babin  United States
Are you sure that there wasn't a short as well? One small section of heatshrink looks like it got hot.
Old 18th August 2017, 10:58 AM   #15
Pulse-R is offline Pulse-R  Australia
I have a new board as well as the repaired one. Haven't had a chance to look back at it yet.
Will reverse engineer the board once I get time.
Digital is only on or off
Old 18th August 2017, 03:13 PM   #16
Tom7227's Avatar
Perry,
I didn't see evidence of that, I wish I would have thought to take a picture of the condition before I pulled the wire off the PCB.
I did ohm the coil to the PCB, totally open, and the coil read 80uh. I would not have expected that disconnection of the circuit, would have caused the overheating condition either.
Let me tell ya, an amp drawing 102 amps while troubleshooting isn't exactly in my comfort zone.
Old 16th November 2017, 11:24 AM   #17
Thanks Perry.
Amp is fixed. Runs at 70kHz or so.
Problem was the megohm resistor on the driver card not soldered properly ( from new possibly) which prevents the saw wave oscillating.
5A draw at idle, 12v supply.
Cheers
Simon.
Xenon 11.5k amplifier output card driverHide this!Advertise here!
Output driver card rrae Car Audio 7 1st August 2017 07:15 AM
Help identify IC - YEUM1007A output driver card Troy Dionne Car Audio 5 17th December 2016 03:35 AM
hi help about output driver card hadidin Car Audio 4 13th April 2016 07:07 PM
DDz1 Output driver (card) diagram rstone2 Class D 0 16th December 2014 12:39 AM
Diablo 2500.1 output driver card brandes.cm Car Audio 6 14th May 2012 12:44 AM
