PCX2400 repair
PCX2400 repair
Old 29th July 2017, 02:19 PM   #1
vincegironda is offline vincegironda
Default PCX2400 repair
I have a PCX2400 showing dead short between all three legs of a bank of A1303's, I pulled one A1303 from the board and the 3 terminals on the board still show a dead short.
Q23,Q240,Q20,Q36,Q27 are all showing dead short.
I checked the power supply transistors for a dead short and they all appear fine.
Any thoughts on what's causing the dead short?
Old 29th July 2017, 02:25 PM   #2
The amp had powered up previously, but was warming up on the defective channel so I shut it down. Now it wont power up without blowing the inline fuse.
Old 29th July 2017, 03:43 PM   #3
Perry Babin is offline Perry Babin  United States
Without base resistors, the pads of all of the parallel transistors are going to read the same (except for the small resistance from the emitter resistors).
Old 29th July 2017, 04:22 PM   #4
Can the power supply transistors in the defective channel be tested in situ or should I pull them to see if the amp powers on?
Old 29th July 2017, 05:24 PM   #5
With the transistors clamped down, place the meter probes on the emitter resistors of the transistors that show short and power up the amp just long enough to get a voltage reading. Power up through a limiter.
One output will have a higher voltage across the emitter resistor. That
's the shorted output.
Old 30th July 2017, 01:44 PM   #6
So I ended up pulling all the power supply transistors and no change, soo I pulled all the output transistors and it turned out Q25 was the only output shirting across all 3 legs.
So I powered it back up and r42 and r43 went up on smoke?
Old 30th July 2017, 09:59 PM   #7
Did you have any other components out of the circuit?
Old 30th July 2017, 10:18 PM   #8
Yes a couple of diodes, I had lifted a couple of legs as they were showing dead short, I resoldered them and the resistors were ok
Old 31st July 2017, 08:26 AM   #9
The amp is pulling around 6.5 amps at idle, the bank of output devices opposite the blown A1303's on the other side is warming up quickly and I noticed the amp pushes the speaker cone up even with no audio?
The amp has been repaired previously, looks like whoever repaired it only replaced a couple of output devices and power supply transistors on both channels.
Old 31st July 2017, 06:59 PM   #10
Do you have shunts on the 2-pin bias headers?
PCX2400 repairHide this!Advertise here!
PPI PCX2400 Jason Smith 616 Car Audio 26 17th June 2017 06:42 PM
PPI PCX2400 - Current draw parallel45 Car Audio 1 13th June 2012 06:59 PM
Repair help? gsindell The Lounge 0 3rd February 2012 10:36 PM
Repair or Get something else.... sboyer Analogue Source 24 29th June 2011 05:04 PM
sub repair...need help ! artie in miami Subwoofers 1 10th April 2009 05:55 PM
