Orion 2250sx Orion 2250sx - Page 5 - diyAudio
Orion 2250sx
Orion 2250sx
Old 18th July 2017, 01:41 AM   #41
RockfordFIx is offline RockfordFIx  United States
Rca shields to positive = 2.8mohm
There is a square wave but it distorts as the transformers begin hissing. Can i remove the rail voltage wires to the audio board tobe sure it's not the audio portion? All the audio outputs checked out fine.
Old 18th July 2017, 02:10 AM   #42
I removed the rail voltage wires both sides one at a time from the audio board just in case the audio portion was casing stress on tje powersupply. No change, I can power the amp for about 45 secs while it's hissing and the outputs heat up. At this point I need to remove the board
Old 18th July 2017, 02:14 AM   #43
Perry Babin is offline Perry Babin  United States
This may be due to the under-sized replacement caps.
Old 23rd July 2017, 11:59 AM   #44
Since ordered caps I ordered a tl494cn ic and optocouplers. Replaced them as I replaced the caps. Amp powers up and still hissing. Have square wave but is a bit fuzzy probably due to transformer hissing. Have rail voltage. But NOW the power LED does not power on. Does power LED switch from the tl494?
Old 23rd July 2017, 12:49 PM   #45
The LED probably gets power from the +15v regulator that feeds pin 8 of the op-amps.
The hissing is likely from the regulators acting too quickly. The the fuzziness related to amplitude or pulse width?
Old 23rd July 2017, 01:05 PM   #46
Okay I will check that next. I am installing the rail voltage wires. Had to replace them cause the old wire was oxidized and would tin.
Old 23rd July 2017, 03:01 PM   #47
I am confused.... after installing the rail voltage wires the power LED is on and the powersupply is not hissing. Just clamped the board and is playing audio 3/4 volume. This is a very clean sounding amp
Old 23rd July 2017, 03:49 PM   #48
If the rail caps are out of circuit with the wires disconnected, that could allow the regulator to operate too quickly. The rail caps would damp the response and stop the noise.
Orion 2250sxHide this!Advertise here!
Orion 2250SX blazer40 Car Audio 11 28th August 2012 11:36 PM
orion 2250sx maush Swap Meet 0 15th August 2010 09:24 PM
Orion 2250sx opamps ? Clipped Car Audio 5 19th October 2007 03:15 AM
Model of Orion 2250sx Clipped Car Audio 2 13th September 2007 02:59 AM
orion 2250sx amp jokerz2 Car Audio 5 26th January 2007 10:02 PM
Copyright ©1999-2017 diyAudio
